470IP Call Transfer
Discussion in '3CX Phone System - General' started by toddwilner, Aug 20, 2010.
  1. toddwilner
    Jan 28, 2009
    5
    I have two Siemens 470IP phones on two different extensions. When I press the R button I can transfer calls to external numbers. How do I transfer internally from one 470IP to the other ie between extensions not on the same base station?
    Thanks in advance for any help
    10,584
    252
    It should be the same method to transfer to another extension, the R button, then extension number. I'm not familiar with that set, a lot probably depends on what SIP message is being sent when the R button is pressed.
  3. toddwilner
    Jan 28, 2009
    5
    Thanks for the reply. It appears when I press the R button it automatically gives me an outside line to transfer - no chance of an internal transfer. What sort of things should I be looking for to change the SIP message?
