480 Configuration Error?
Discussion in '3CX Phone System - General' started by dittobox, Mar 10, 2013.
  1. dittobox
    Mar 10, 2013
    I recently started getting this error (see log below) when trying to register with the SIP server. I'm using SP4 of v11. I can receive calls but I cannot make them, I just get the same 480 error back from the SIP server.
    Here's what I've done to fix the issue:
    -Rebooted the DSL modem providing the trunk
    -Checked routing
    -Checked over all of my VOIP provider settings (nothing has changed!)
    -Deleted and recreated the VOIP provider in 3CX
    -Checked configuration against another site that is working fine using the same VOIP provider and SIP server.
    -Used Wireshark to see what the traffic looked like, all seemed correct.
    Here's the log:
    Code:
    10-Mar-2013 11:39:49.002	Unregistered line: Lc:10000(@Group Six II[<sip:NorthGlenVillas@10.6.6.131:5060>])
    10-Mar-2013 11:39:49.002	Removed registration for []
    10-Mar-2013 11:39:49.000	[CM504007]: Next attempt to register Lc:10000(@Group Six II[<sip:NorthGlenVillas@10.6.6.131:5060>]) is scheduled in 5 minute
    10-Mar-2013 11:39:48.972	[CM504005]: Registration failed for: Lc:10000(@Group Six II[<sip:NorthGlenVillas@10.6.6.131:5060>]); Cause: Cause: 480 Configuration error with selected binding/REGISTER from 10.6.6.131:5060
    10-Mar-2013 11:39:48.972	Updating device Dev(1):[sip:NorthGlenVillas@10.6.6.131:5060 / NorthGlenVillas]: No update on error responses: SipResp: 480 tid=5e77087ada2e4d07 cseq=REGISTER / 1 from(wire)
    10-Mar-2013 11:39:48.829	[CM504003]: Sent registration request for Lc:10000(@Group Six II[<sip:NorthGlenVillas@10.6.6.131:5060>])
    I'm working with our VOIP provider but it's been since Friday morning (48 hours downtime!!!) and they haven't been proactive at all in helping me.
    11,129
    330
    When did this begin to fail? What was changed at that time, that may be causing this? Hardware/firmware/network/software update?
  3. dittobox
    Mar 10, 2013
    After finally getting with some who knew what they were doing we managed to find out that the contact IP was wrong in their config.
    80+ hours of down time over something I told them to check at the beginning. Neat.
