486 Busy Here; from IP:x.x.x.x:5060
Discussion in '3CX Phone System - General' started by fonewiz, Jul 28, 2015.
  1. fonewiz
    May 13, 2015
    44
    We have a 3CX Cloud install with only one active tenant so far up and running.
    This customer's install sends me emails a few times a day that look like the one I pasted below. This seemed to me like 3CX was alerting me that the trunk was reporting busy so I contacted our SIP trunk provider.
    The provider came back and said on all the outbound calls in question (the ones that generated those emails to me) just had busy lines and their trunk is reporting that back to 3CX.
    So, two questions:
    1- Does that sound right to you? Seems like it's more of a trunk busy error, not a far end busy error but??
    2- Why would anyone want 3CX to send them an alert email every time someone dials an outbound number with a busy line on the far end? Why is this a "Feature"?
    I have all the alerts turned on in the email notifications section except "Registration Status". The only option that's checked that could possibly relate is the option labeled "Trunk provider responds to request with an error code". If I turn this off then I don't think I would be notified if a real error occurred on the trunk.
    Any thoughts would be appreciated, thanks in advance.
    Email sample mentioned above, got three of these in a row today. I changed the numbers, IP addresses etc to protect the innocent :) IP:x.x.x.x:5060 = my sip trunk IP with Level3. 1NPANXXXXXX = the phone number the 3CX user dialed.
    -----Original Message-----
    Sent: Monday, July 27, 2015 3:49 PM
    To: My Name <My.Name@mydomain.com>
    Subject: 3CX Phone System TenantName Email Notification - ID 12294 - Error response received from Trunk/Provider
    (0) pbxname 7/27/2015 3:49:23 PM
    Event source: 3CXPhoneSystem pbxname
    Call or Registration to 1NPANXXXXXX@(Ln.10001@Level3 Trunk) has failed. [ V4 x.x.x.x:5060 UDP target domain=unspecified mFlowKey=1064 ] replied: 486 Busy Here; from IP:x.x.x.x:5060
  2. dig1234
    Jun 1, 2015
    75
    I was getting same alerts, seems odd for default setting but all you have to do is remove that error type from alerting. See this thread:
    http://www.3cx.com/forums/yealink-486-busy-here-messages-21150.html
  3. leejor
    11,073
    323
    I have also had reports when the called party was busy.
  4. practiceforces
    May 3, 2010
    Did anybody find the answer for this? I have versions 12 and same issue just popped up with Patton switch and VOIP lines. outgoing calls some time says busy here and some time it goes fine. so cant understand whats the problem could be?
  5. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    The response is from the trunk provider, not 3CX. I ended up canning them by rule.. like the wrong dials generating 404s.
    Flowroute hasn't done me wrong in that regard.. most always the other end was legit busy.
