487 Request Terminated
Discussion in '3CX Phone System - General' started by Tarheels, Sep 22, 2017.
  1. Tarheels
    Dec 22, 2016
    36
    Why would I get 487 Request Terminated/INVITE from 127.0.0.1:5488 and 487 Request Cancelled/INVITE from the public IP:5069 when I page the phones in a page group. It doesn't do this to all the extensions.
  2. AndreasPo_3CX
    AndreasPo_3CX Support Team
    Aug 10, 2017
    138
    12
    Hello @Tarheels ,
    what phones are you using? are they on the latest firmware? Does this happen only with one phone? How are the phones in the paging group provisioned? (Local, via SBC, Stun)
    Also can you elaborate a bit on what exactly is happening? You page a group but it doesn't open the phones speaker?
  3. Tarheels
    Dec 22, 2016
    36
    The phones are provisioned local and the firmware is up to date. There are 30 phones in the paging group and about half of the phones speakers don't open up
  4. AndreasPo_3CX
    Aug 10, 2017
    138
    12
    Is this a new installation or was this system upgraded from a previous version?
  5. Tarheels
    Dec 22, 2016
    36
    This is a new install
  6. Tarheels
    Dec 22, 2016
    36
    Any ideas what could be causing this
  7. AndreasPo_3CX
    Aug 10, 2017
    138
    12
    What phones are you using in this paging group (brand,model) and what ring strategy are you using for the paging group (Paging or Paging Multicast)?
    Also which version of the PBX are you running?
  8. Tarheels
    Dec 22, 2016
    36
    Yealink SIP-T42S phones and I am using page. PBX version 15.5
  9. AndreasPo_3CX
    Aug 10, 2017
    138
    12
    I have sent you a PM, please check your inbox.
  10. Tarheels
    Dec 22, 2016
    36
    How many phones can be in a ring group ? I currently have 30 in the one that isn't working right.
  11. AndreasPo_3CX
    Aug 10, 2017
    138
    12
