4G Router with Fixed Handset
Discussion in '3CX Phone System - General' started by joshhough, Jan 10, 2014.
  1. joshhough
    Feb 22, 2011
    72
    Bit of an odd request. Looking at putting a 4G router on some boats which pass up and down a river with strong signal. The Boats would have a 4G Router for their tills to communicate and they have 3CX in their office. What i'd like to do is put a fixed handset (Snom 710 or similar) - has anybody tried this, well, i mean over 4G and has anybody had any luck?
    Thanks,
    Josh
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Assuming that you are speaking of using a 4G WiFi hotspot and you are speaking of using the phones with a WiFi dongle, the answer is yes. We have done this many times and recently in an office with 5 phones using the OpenVPN built in the grand stream phones.
  3. joshhough
    Feb 22, 2011
    72
    What in fact i was thinking of doing is using a Draytek Router with a USB 4G Dongle, then the phones connected via Ethernet to the router. I presume the same will apply and it will work.
    Cheers,
    Josh
