5 ISDN lines - what is the best solution
Discussion in '3CX Phone System - General' started by jflietstra, Oct 16, 2009.
  1. jflietstra
    Dec 11, 2008
    A customer has 5 incoming ISDN-1 (2 channels) lines
    What is the best hardware solution to handle this?
    With kind regards
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I think you will probably be looking for something like the Patton 4554
    http://www.888voipstore.com/patton-smartnode-4554.html
