5 Second Delay in outbound calls via Patton ISDN Gateway
Discussion in '3CX Phone System - General' started by ziptalk, Jan 14, 2009.
  1. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    I have noticed that when I dial outbound there is a long delay from the IP Phones and Soft Phone. Approximately 5 seconds. On examing the Server Activity included below I have noticed that it looks like it's trying to route via one of the ports that I have not plugged an ISDN box into. I would expect it begin at the first available or at least the lowest port number.I only have one ISDN 2e plugged into the Patton for testing, although when I ran the wizard I provisioned all 4 ports (10002 - 10005). Is there anyway I can tell the 3CX to not try and use those ports that are not plugged in ? And most strange is that the call goes out on port 10003 of which I have nothing physically plugged into. :roll: 100002 is the live port that has an ISDN plugged into it. Appreciate any help on this one. Lots of screenshots below to assist.
    Thanks,
    Lewis
    Code:
    [color=#FF0000]20:11:02.510  [CM503003]: Call(42): Call to sip:01932233966@192.168.66.58:5066 has failed; Cause: 503 Service Unavailable; from IP:192.168.66.58:5066
    20:10:58.304  [CM503003]: Call(42): Call to sip:01932233966@192.168.66.58:5064 has failed; Cause: 503 Service Unavailable; from IP:192.168.66.58:5064
    20:10:54.098  [CM503003]: Call(42): Call to sip:01932233966@192.168.66.58:5062 has failed; Cause: 503 Service Unavailable; from IP:192.168.66.58:5062[/color]
    20:10:49.932  [CM503004]: Call(42): Calling: Unknown:01932233966@(Ln.10003@Patton ISDN Gateway)@[Dev:sip:10003@192.168.66.58:5062, Dev:sip:10004@192.168.66.58:5064, Dev:sip:10005@192.168.66.58:5066, Dev:sip:10002@192.168.66.58:5060]
    20:10:49.862  [CM503010]: Making route(s) to <sip:901932233966@sip.ziptechservices.co.uk:5060>
    20:10:49.852  [CM505001]: Ext.3966: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.4184.0] Transport: [sip:192.168.66.57:5060]
    20:10:49.822  [CM503001]: Call(42): Incoming call from Ext.3966 to <sip:901932233966@sip.ziptechservices.co.uk:5060>
  2. nb
    nb Support Team
    Jun 7, 2007
    2,126
    150
    Hi!
    There is a way yes. You can do this by disabling the lines you are not using.
    Click on the actual line and uncheck both "Allow incoming calls on this line" "Allow outgoing calls on this line" the lines you are not using will unregister. The PBX will not hunt then.
  3. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Thank you for that answer, cured my problem a treat. I didn't fancy reprovisioning with less lines since I hope to cut this over from my test ISDN to production with 4 lots of ISDN 2e. Thanks again. Lewis
