500 Internal Server error on Phone Provisioning V14
Discussion in '3CX Phone System - General' started by allteks, Sep 9, 2015.
  1. allteks
    Dec 16, 2014
    Just upgraded from 12.5 to 14 and I now get a "500 Internal Server Error" when I go to the Phone Provisioning Tab. All worked fine in 12.5.
    Paths and URL's all look correct. Folders exist on the servers etc. Any idea how to resolve?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    I believe the issue is that through your windows features the ASP.NET is not installed, can you verify and install if missing, then restart services and web server?
  3. tsteffens
    Jul 14, 2011
    85
    Had this same message and can confirm installing ASP.NET in windows features fixed the issue.
