503 Error: How to specify ext IP in SDP?
Discussion in '3CX Phone System - General' started by Sopock, Jul 24, 2016.
  1. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    Hi!
    Consider scenario when provider has assigned static private IP(class A) for voice interface. In this case, 3CX will use own local IP in SDP(192.*)
    No effect on Use this IP Address option.
    Now I wonder, maybe MSEXTERNALADDRESS should be present in 3cxmediaserver.ini?
    Thanks.
  2. andreaschr
    andreaschr Support Team
    Oct 26, 2015
    93
    6
    Hi Sopock ,
    Edit the Voip Provider go to Options and enable "Put Public IP in SIP VIA Header".
    Enter the ip you want there.
  3. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    Hi andreaschr,
    unfortunately still same error. I should point out there are no errors when using softphone in which external IP can be set.
    You can probably test this case even in virtual V14 which can act as provider. Only trouble could be wrong kind of virtual NAT... :idea:
    Code:
     Private                       NAT                         Private
         Network 1                      │                          Network 2
        │  V14   │                      │                         │   V15  │
  4. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    Local SDP vs Remote SDP
    Any progress on this simple and longstanding issue?
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    After investigating about this scenario (example screenshots below), the 3CX software in the SDP will always put the NIC IP:
    To be more specific, ONLY in the scenario where in the Provider Settings:
    - The Providers Server IP is an IP in the LAN ranges (10.0.0.0/8, 172.16.0.0/12, 192.168.0.0/16)
    - You have NOT specified an Outbound Proxy
    Then regardless if you have specified a specific reply IP address in the Provider Settings, it will be disregarded and the NIC IP will be used.
    To further clarify, in the above example screenshot, even if in the Provider Settings an put "Use this IP" and set 192.168.9.172, when making calls, the 3CX Server in the SDP will send 192.168.2.250.
  6. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    Thank you for investigation.
    It seems there is no change if I set same name for Outbound Proxy. Maybe I should mention that ATA/IAD will register to 3CX only by tcp using Wan1 IP. That could explain lack of Outbound Proxy/STUN?
  7. NickD_3CX
    Jun 2, 2014
    1,255
    63
    I don't think that should make a difference. Generally if you have a Proxy and it has a LAN IP, typically it would be on your network so it sending the NIC IP would not be a problem in that scenario. Sorry I didn't clarify that better.
