503 Service Unavailable
Discussion in '3CX Phone System - General' started by KOUSIS, Nov 24, 2010.
  1. KOUSIS
    Nov 17, 2010
    26
    Hello
    I'm trying to install the system and i can make calls between the extensions but not outside
    I have the Grandstream 4104 and i followed everything in manual but when i'm calling i take this error
    10:20:15.306 [CM503020]: Normal call termination. Reason: Server Failure
    10:20:15.306 [CM503016]: Call(1): Attempt to reach <sip:06936158137@192.168.1.2> failed. Reason: Server Failure
    10:20:15.302 [CM503003]: Call(1): Call to sip:6936158137@192.168.1.160:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.1.160:5060
    10:20:15.207 [CM503025]: Call(1): Calling PSTNline:6936158137@(Ln.10000@Grandstream_GXW4104 )@[Dev:sip:10003@192.168.1.160:5066]
    10:20:15.195 [CM503003]: Call(1): Call to sip:6936158137@192.168.1.160:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.1.160:5060
    10:20:15.104 [CM503025]: Call(1): Calling PSTNline:6936158137@(Ln.10000@Grandstream_GXW4104 )@[Dev:sip:10002@192.168.1.160:5064]
    10:20:15.086 [CM503003]: Call(1): Call to sip:6936158137@192.168.1.160:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.1.160:5060
    10:20:14.990 [CM503025]: Call(1): Calling PSTNline:6936158137@(Ln.10000@Grandstream_GXW4104 )@[Dev:sip:10001@192.168.1.160:5062]
    10:20:14.977 [CM503003]: Call(1): Call to sip:6936158137@192.168.1.160:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.1.160:5060
    10:20:14.929 [CM503025]: Call(1): Calling PSTNline:6936158137@(Ln.10000@Grandstream_GXW4104 )@[Dev:sip:10000@192.168.1.160:5060]
    10:20:14.866 [CM503004]: Call(1): Route 1: PSTNline:6936158137@(Ln.10000@Grandstream_GXW4104 )@[Dev:sip:10000@192.168.1.160:5060,Dev:sip:10001@192.168.1.160:5062,Dev:sip:10002@192.168.1.160:5064,Dev:sip:10003@192.168.1.160:5066]
    10:20:14.840 [CM503010]: Making route(s) to <sip:06936158137@192.168.1.2>
    10:20:14.837 [CM505001]: Ext.203: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.50.0.50] PBX contact: [sip:203@192.168.1.2:5060]
    10:20:14.823 [CM503001]: Call(1): Incoming call from Ext.203 to <sip:06936158137@192.168.1.2>
    10:19:30.728 [CM504001]: Ext.203: new contact is registered. Contact(s): [sip:203@192.168.1.233:5062/203]
    192.168.1.233 is the Phone
    192.168.1.2 is the server
    192.168.1.160 is the Grandstream
    203 is the extension
    Thank you
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    This usually would indicate that the grandstream line is not plugged or is malfunctioning, please test this by connecting an analog phone to the line and make a call. If this works then.
    1, Ensure grandstream is running the latest supproted firmware.
    2. Factory reset the phone and set it up using the Config guide.
