504 Overloaded?
Discussion in '3CX Phone System - General' started by optima, May 22, 2012.
  1. optima
    Apr 10, 2012
    From time to time I'm seeing the following error messages in the 3CX Server Event Log:
    Call to Primus SIP Trunk has failed. sip:xxxxxxxxxx@bvoice.primus.ca:5060 replied: 504 Overloaded; from IP:209.90.170.38:5060
    This results in the system being unregistered until 3CX tries again five minutes later.
    Anyone have any idea where I should be looking for the problem? Is it something on the provider side, or a problem with my 3CX setup?
    Thanks in advance,
    Ulrich
  2. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Pretty sure that is a provider side error. I think errors in the 500-5xx range are server error responses
  3. paul.hadley
    paul.hadley New Member
    Aug 24, 2010
    122
    504 - Server Timed Out
    It is message from the Primus server that it did not receive a response from the gateway (server) it was placing your call on, so a fault on their side.
    This is a full of list of codes I have
    100 Trying: Extended search being performed may take a significant time so a forking proxy must send a 100 Trying response
    180 Ringing: Destination user agent received INVITE, and is alerting user of call.
    181 Call is Being Forwarded: Servers can optionally send this response to indicate a call is being forwarded.
    182 Queued: Indicates that the destination was temporarily unavailable, so the server has queued the call until the destination is available. A server may send multiple 182 responses to update progress of the queue.
    183 Session in Progress: This response may be used to send extra information for a call which is still being set up.
    2xx—Successful Responses: 200 OK
    202 accepted: Indicates that the request has been accepted for processing, but the processing has not been completed
    204 No Notification [RFC5839]
    3xx—Redirection Responses
    300 Multiple Choices
    301 Moved Permanently
    302 Moved Temporarily
    305 Use Proxy
    380 Alternative Service
    4xx—Client Failure Responses
    400 Bad Request
    The request could not be understood due to malformed syntax.
    401 Unauthorized
    The request requires user authentication. This response is issued by UASs and registrars.
    402 Payment Required
    Reserved for future use.
    403 Forbidden
    The server understood the request, but is refusing to fulfill it.
    404 Not Found (User not found)
    The server has definitive information that the user does not exist at the domain specified in the Request-URI This status is also returned if the domain in the Request-URI does not match any of the domains handled by the recipient of the request.
    405 Method Not Allowed
    The method specified in the Request-Line is understood, but not allowed for the address identified by the Request-URI.
    406 Not Acceptable
    The resource identified by the request is only capable of generating response entities that have content characteristics not acceptable according to the Accept header field sent in the request.
    407 Proxy Authentication Required
    The request requires user authentication. This response is issued by proxys.
    408 Request Timeout
    Couldn't find the user in time.
    409 Conflict
    User already registered [RFC2543]
    410 Gone
    The user existed once, but is not available here any more.
    412 Conditional Request Failed
    Conditional Request Failed [RFC3903]
    413 Request Entity Too Large
    Request body too large.
    414 Request-URI Too Long
    The server is refusing to service the request because the Request-URI is longer than the server is willing to interpret.
    415 Unsupported Media Type
    Request body in a format not supported.
    416 Unsupported URI Scheme
    Request-URI is unknown to the server.
    417 Unknown Resource-Priority
    Unknown Resource-Priority [RFC4412]
    420 Bad Extension
    Bad SIP Protocol Extension used, not understood by the server.
    421 Extension Required
    The server needs a specific extension not listed in the Supported header.
    422 Session Interval Too Small
    It is generated by a UAS or proxy when a request contains a Session-Expires header field with a duration below the minimum timer for the server [RFC4028]
    423 Interval Too Brief
    Expiration time of the resource is too short.
    424 Bad Location Information
    Bad Location Information [RFC6442]
    428 Use Identity Header
    Use Identity Header [RFC4474]
    429 Provide Referrer Identity
    Provide Referrer Identity [RFC3892]
    433 Anonymity Disallowed
    Anonymity Disallowed [RFC5079]
    436 Bad Identity-Info
    Bad Identity-Info [RFC4474]
    437 Unsupported Certificate
    Unsupported Certificate [RFC4474]
    438 Invalid Identity Header
    Invalid Identity Header [RFC4474]
    480 Temporarily Unavailable
    Callee currently unavailable.
    481 Call/Transaction Does Not Exist
    Server received a request that does not match any dialog or transaction.
    482 Loop Detected.
    Serve has detected a loop.
    483 Too Many Hops
    Max-Forwards header has reach value '0'.
    484 Address Incomplete
    Request-URI incomplete.
    485 Ambiguous
    Request-URI is ambiguous.
    486 Busy Here
    Callee is busy.
    487 Request Terminated
    Request has terminated by bye or cancel.
    488 Not Acceptable Here
    Some aspects of the session description of the Request-URI is not acceptable.
    489 Bad Event
    Bad Event [RFC3265]
    491 Request Pending
    Server has some pending request from the same dialog.
    493 Undecipherable
    Request contains an encrypted MIME body, which recipient cannot decrypt.
    494 Security Agreement Required
    Security Agreement Required [RFC3329]
    5xx—Server Failure Responses
    500 Server Internal Error
    501 Not Implemented: The SIP request method is not implemented here
    502 Bad Gateway
    503 Service Unavailable
    504 Server Time-out
    505 Version Not Supported: The server does not support this version of the SIP protocol
    513 Message Too Large
    580 Precondition Failure
    6xx—Global Failure Responses
    600 Busy Everywhere
    603 Decline
    604 Does Not Exist Anywhere
    606 Not Acceptable
