5080 port is busy
vsi
Installation Failed to 3CX 5.1. Message error: 5080 The Specified port is busy or in use.Before I uninstalled version 5.0.
What solution ?
I had the same problem.
I fixed it by:
1) Reinstalling version 5.0
2) Reboot
3) Removing version 5.0
4) Reboot
5) Installing version 5.1
Hi folks, Im a newbie to 3CX. Im trying to install the v5.1 and have failed.
I have also faced same problem, I have searched for v5.0 but all download links are pointing to the v5.1 link.Is there somewhere i can download v5.0 from?
many thanks in advance
vamutiti
Hi Vamutiti
I Have 5.0 3752 and 5.0 3790 But I do not know The 3CX will agree with old version installation or not?
Thanks amygoda. I would like to try out the suggestion of installing v5.0 then v5.1. Can you advise where i can download this v5.0.
many thanks
Same problem with the new version.
:roll:
Hi AndreasMetal,
You should be stop the service of "3CX VoIP Client Tunnel" before install 3CX phone system. Please find the command as below:
net stop "3CX VoIP Client Tunnel"
Thanks !!
I tried this but says in greek: "Δεν επιτρέπεται η πρόσβαση". That does mean "Access Restricted"
What can i do now ?
Thanks..
Ehm..I have write the command in command promt, right?
Byeeeeee
8) 8) 8) 8) 8) :shock: :shock:
I stop the service from "Task Manager" > "Service Manager"
And works :D
Thanksssss
Getting Started - Admin
matchofficees
Get 3CX - Absolutely Free!
3CX
