5291 unable to hear 5230 is there anything in this log?
Discussion in '3CX Phone System - General' started by rslattery, Mar 22, 2018.
  1. rslattery
    Dec 20, 2016
    13
    03/22/2018 10:27:02 AM - L:12460.2[Extn:5230] has joined to L:12460.1[Extn:5291]
    03/22/2018 10:26:56 AM - [CM503025]: Call(C:12460): Calling T:Extn:5230@[Dev:sip:5230@192.168.21.200:64630;rinstance=0-0cb319c00e3f42d0bc94ab2f44f4a7bf;ob] for L:12460.1[Extn:5291]
    03/22/2018 10:26:56 AM - [CM503027]: Call(C:12460): From: Extn:5291 ("Sean Robillard" <sip:5291@10.2.100.250:5060>) to T:Extn:5230@[Dev:sip:5230@192.168.21.200:64630;rinstance=0-0cb319c00e3f42d0bc94ab2f44f4a7bf;ob]
    03/22/2018 10:26:56 AM - [CM503004]: Call(C:12460): Route 1: from L:12460.1[Extn:5291] to T:Extn:5230@[Dev:sip:5230@192.168.21.200:64630;rinstance=0-0cb319c00e3f42d0bc94ab2f44f4a7bf;ob]
    03/22/2018 10:26:56 AM - [Flow] Call(C:12460): has built target endpoint: Extn:5230 for call from L:12460.1[Extn:5291]
    03/22/2018 10:23:35 AM - L:12454.2[Extn:5230] has joined to L:12454.1[Extn:5291]
    03/22/2018 10:23:21 AM - [CM503025]: Call(C:12454): Calling T:Extn:5230@[Dev:sip:5230@192.168.21.200:64630;rinstance=0-0cb319c00e3f42d0bc94ab2f44f4a7bf;ob] for L:12454.1[Extn:5291]
    03/22/2018 10:23:21 AM - [CM503027]: Call(C:12454): From: Extn:5291 ("Sean Robillard" <sip:5291@10.2.100.250:5060>) to T:Extn:5230@[Dev:sip:5230@192.168.21.200:64630;rinstance=0-0cb319c00e3f42d0bc94ab2f44f4a7bf;ob]
    03/22/2018 10:23:21 AM - [CM503004]: Call(C:12454): Route 1: from L:12454.1[Extn:5291] to T:Extn:5230@[Dev:sip:5230@192.168.21.200:64630;rinstance=0-0cb319c00e3f42d0bc94ab2f44f4a7bf;ob]
    03/22/2018 10:23:21 AM - [Flow] Call(C:12454): has built target endpoint: Extn:5230 for call from L:12454.1[Extn:5291]
    03/22/2018 10:21:02 AM - L:12449.1[Extn:5291] forwards call from Extn:5230 to VMail:9999 based on rule Fwd[Available/NoAnsw]
    03/22/2018 10:21:02 AM - L:12449.1[Extn:5291] failed to reach Extn:5230, reason No Answer
    03/22/2018 10:20:42 AM - [CM503025]: Call(C:12449): Calling T:Extn:5230@[Dev:sip:5230@192.168.21.200:64630;rinstance=0-0cb319c00e3f42d0bc94ab2f44f4a7bf;ob] for L:12449.1[Extn:5291]
    03/22/2018 10:20:42 AM - [CM503027]: Call(C:12449): From: Extn:5291 ("Sean Robillard" <sip:5291@10.2.100.250:5060>) to T:Extn:5230@[Dev:sip:5230@192.168.21.200:64630;rinstance=0-0cb319c00e3f42d0bc94ab2f44f4a7bf;ob]
    03/22/2018 10:20:42 AM - [CM503004]: Call(C:12449): Route 1: from L:12449.1[Extn:5291] to T:Extn:5230@[Dev:sip:5230@192.168.21.200:64630;rinstance=0-0cb319c00e3f42d0bc94ab2f44f4a7bf;ob]
    03/22/2018 10:20:42 AM - [Flow] Call(C:12449): has built target endpoint: Extn:5230 for call from L:12449.1[Extn:5291]
    03/21/2018 12:34:13 PM - L:11961.1[Extn:5291] failed to reach Extn:5230, reason Not Found
    03/21/2018 12:34:13 PM - Call to T:Extn:5230@[Dev:sip:5230@192.168.21.200:50195;transport=TCP;rinstance=1-f0275b3a1fc34b6dab0a6af0a94db911;ob] from L:11961.1[Extn:5291] failed, cause: Cause: 404 Not Found/INVITE from 127.0.0.1:5080
    03/21/2018 12:34:13 PM - [CM503025]: Call(C:11961): Calling T:Extn:5230@[Dev:sip:5230@192.168.21.200:50195;transport=TCP;rinstance=1-f0275b3a1fc34b6dab0a6af0a94db911;ob] for L:11961.1[Extn:5291]
    03/21/2018 12:34:13 PM - [CM503027]: Call(C:11961): From: Extn:5291 ("Sean Robillard" <sip:5291@10.2.100.250:5060>) to T:Extn:5230@[Dev:sip:5230@192.168.21.200:50195;transport=TCP;rinstance=1-f0275b3a1fc34b6dab0a6af0a94db911;ob]
    03/21/2018 12:34:13 PM - [CM503004]: Call(C:11961): Route 1: from L:11961.1[Extn:5291] to T:Extn:5230@[Dev:sip:5230@192.168.21.200:50195;transport=TCP;rinstance=1-f0275b3a1fc34b6dab0a6af0a94db911;ob]
    03/21/2018 12:34:13 PM - [Flow] Call(C:11961): has built target endpoint: Extn:5230 for call from L:11961.1[Extn:5291]
    03/21/2018 12:31:08 PM - L:11954.1[Extn:5291] failed to reach Extn:5230, reason Not Found
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,003
    191
    This log shows that 5291 couldn't even reach 5230 - never mind not hear them.
    IP Phoines? Softphones? Same Lan?
  3. rslattery
    Dec 20, 2016
    13
    The caller 5291 cannot hear the receiver but the receiver can hear him.
    Both handset/soft phone to receiver using a soft phone. I gave 5230 the receiver a new extension and it worked fine. When I switched back to 5230 it was not working gain.
    Same network different subnets and different locations/sites connected with an mpls.
    I was going to do a uninstall of the client with a third party tool and reinstall. It's just odd that it is with that extension and other users seem to be able to call the receiver extension fine.
