7.1 & RFC compliant email addresses
Discussion in '3CX Phone System - General' started by Ase, Mar 22, 2009.
  1. Ase
    Ase
    Jan 12, 2009
    58
    Just tested the 7.1 RC1.
    When installing the system it does not allow RFC compliant email addresses.
    Will the final 7.1 do that (I do not want to send out emails that can be routed internally)?
    More info on the issue is found at:
    http://www.3cx.com/forums/exchange-2007-and-3cx-on-same-server-8549.html#p43922
    Regards,
    Ase
