7 Day wait for FQDN
Discussion in '3CX Phone System - General' started by Adam Wride, Apr 2, 2018.
  1. Adam Wride
    Jul 28, 2017
    8
    Had some major issues getting our 3cx server to upgrade over the weekend, desparately trying to get it back online at the moment.
    Reinstalling 3cx from a back up which we have done a few times, it's now saying that it can't activate the fqdn, need to wait 7 days to try again, anyone had this before? Really need it as the backup isn't showing any extensions when we use a different fqdn.
    Please help!
    Adam
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    674
    101
    I haven't seen that before but it sounds like you might have restored a few times and hit some sort of rate limiting. As far as no extensions showing.. you mean not registering or actually no extensions in the extensions tab? Not registering would make sense if the endpoints were using the FQDN but the extensions tab being empty sounds like a bad backup or one taken before the extensions were created.
  3. Adam Wride
    Jul 28, 2017
    8
    What's weird about it as I can see the data in the backup, I've pulled it apart separately to check it, at the moment the work around for me is to completely rebuild the phone server.
    Do you know any way of checking a back up?
  4. Jor3cx
    Oct 26, 2017
    11
    Hello Adam,
    Do you get the next error?
    ERROR creating FQDN:
    Certificate Authority Error: ID (429) - too many certificate requests for the same FQDN. This means you have tried to generate a certificate for this FQDN more than 5 times in the last 7 days. If you want this certificate you need to wait until the counter is adjusted. If you cannot wait, you will need to choose another FQDN. To re-install 3CX using the same license key with a different FQDN requires you to release your current FQDN which frees your license. Follow this guide: https://www.3cx.com/docs/fqdn-already-in-use/
    Than you have to wait 7 days, or you create a ticket in the customerportal of 3cx and they can help you.
    grz jor3cx
  5. Adam Wride
    Jul 28, 2017
    8
    Thank you, I did change the FQDN but it still didn't insert the data from the backup - there were no errors during the restore, just hasn't put any of my configuration in...
    I will raise a support ticket with 3CX and try to get the FQDN reset
  6. StefanW
    Jun 2, 2009
    1,153
    70
    when you hit this message then even 3CX can not lift it as it is defined in the cert issuer process: https://letsencrypt.org/docs/rate-limits/. Only a unbound and selection of another FQDN can be done, or wait.
