7 digit dialing for local numbers?
Discussion in '3CX Phone System - General' started by mutti_wilson, May 9, 2008.
  1. mutti_wilson
    May 2, 2008
    53
    I am trying to get 7 digit dialing for local numbers and 11 digit for long distance numbers working. Here is my rule for 7 digit dialing.
    Also with long distance dialing do i have to dial a "1" before the area code or would it act as a cellphone would? 3CX is awesome!
  2. mutti_wilson
    May 2, 2008
    53
    Got it figured out:) Had to change the strip number field to 0 and prepend the area code.
