7906 will not dial out - drops digits
Discussion in '3CX Phone System - General' started by ajohnson443, Apr 8, 2012.
  1. ajohnson443
    Mar 27, 2012
    30
    Cisco 7906G when out-dialing will drop all but the 1st digit.
    Cisco 7960G is function fine. Below is a log from 3CX when placing a call from first the the 7960 and then the 7906. I have attached my phone configs.. Please help :!: :!: :!:
    01:40:26.718 [CM503008]: Call(12): Call is terminated
    01:40:22.359 [CM503007]: Call(12): Device joined: sip:9046474349@sip.broadvoice.com:5060
    01:40:22.343 [CM503007]: Call(12): Device joined: sip:1004@10.232.1.67:51724;transport=tcp
    01:40:22.234 [CM505003]: Provider:[BroadVoice] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:9046474349@108.197.214.151:5060]
    01:40:22.234 [CM503002]: Call(12): Alerting sip:9046474349@sip.broadvoice.com:5060
    01:40:21.828 [CM503025]: Call(12): Calling VoIPline:mad:(Ln.10000@BroadVoice)@[Dev:sip:9046474349@sip.broadvoice.com:5060]
    01:40:21.703 [CM503004]: Call(12): Route 1: VoIPline:mad:(Ln.10000@BroadVoice)@[Dev:sip:9046474349@sip.broadvoice.com:5060]
    01:40:21.703 [CM503010]: Making route(s) to <sip:9@10.232.1.66;user=phone>
    01:40:21.703 [CM505001]: Ext.1004: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7906G/8.0] PBX contact: [sip:1004@10.232.1.66:5060;transport=TCP]
    01:40:21.687 [CM503001]: Call(12): Incoming call from Ext.1004 to <sip:9@10.232.1.66;user=phone>
    01:40:05.953 [CM503008]: Call(11): Call is terminated
    01:40:02.015 [CM503007]: Call(11): Device joined: sip:9046474349@sip.broadvoice.com:5060
    01:40:02.000 [CM503007]: Call(11): Device joined: sip:1001@10.232.1.76:5060
    01:39:43.859 Currently active calls - 1: [11]
    01:39:39.421 [CM505003]: Provider:[BroadVoice] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:9046474349@108.197.214.151:5060]
    01:39:39.421 [CM503002]: Call(11): Alerting sip:9046474349@sip.broadvoice.com:5060
    01:39:37.687 [CM503025]: Call(11): Calling VoIPline:9878555@(Ln.10000@BroadVoice)@[Dev:sip:9046474349@sip.broadvoice.com:5060]
    01:39:37.531 [CM503004]: Call(11): Route 1: VoIPline:9878555@(Ln.10000@BroadVoice)@[Dev:sip:9046474349@sip.broadvoice.com:5060]
    01:39:37.531 [CM503010]: Making route(s) to <sip:99878555@10.232.1.66>
    01:39:37.531 [CM505001]: Ext.1001: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7960G/7.5] PBX contact: [sip:1001@10.232.1.66:5060]
    01:39:37.515 [CM503001]: Call(11): Incoming call from Ext.1001 to <sip:99878555@10.232.1.66>
    01:37:13.609 [CM503008]: Call(10): Call is terminated
    01:37:07.171 [CM503007]: Call(10): Device joined: sip:9046474349@sip.broadvoice.com:5060
    01:37:07.078 [CM505003]: Provider:[BroadVoice] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:9046474349@108.197.214.151:5060]
    01:37:06.671 [CM503025]: Call(10): Calling VoIPline:mad:(Ln.10000@BroadVoice)@[Dev:sip:9046474349@sip.broadvoice.com:5060]
    01:37:06.515 [CM503010]: Making route(s) to <sip:9@10.232.1.66;user=phone>
    01:37:06.500 [CM503001]: Call(10): Incoming call from Ext.1004 to <sip:9@10.232.1.66;user=phone>
    01:36:52.843 [CM503016]: Call(9): Attempt to reach <sip:7@10.232.1.66;user=phone> failed. Reason: Not Found
    01:36:52.843 [CM503010]: Making route(s) to <sip:7@10.232.1.66;user=phone>
    01:36:52.828 [CM503001]: Call(9): Incoming call from Ext.1004 to <sip:7@10.232.1.66;user=phone>
    01:32:27.062 Currently active calls - 1: [8]
    01:32:23.781 [CM503007]: Call(8): Device joined: sip:1004@10.232.1.67:51724;transport=tcp
  2. ajohnson443
    Mar 27, 2012
    30
    At this point I am not sure if it dropping digits at 3CX or if the phone is just not sending them all. When I dial it immediately sends the 1st digit pressed and places the call as if thats the only digit dialed.. I am confused. :cry:
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    Check the phone's digit timeout or something similar by logging into the handset via the IP Address.
  4. ajohnson443
    Mar 27, 2012
    30
    While looking for info on digittime out I ran across info on the dialplan.xml... doh!
    Created a quick dialplan.xml and it seems to be working fine. Thanks for nudging me in the right direction.
    <DIALTEMPLATE>
    <TEMPLATE MATCH="10.." Timeout="0"/> <!-- internal extensions are 10xx -->
    <TEMPLATE MATCH="91.........." TIMEOUT="0" /> <!-- Long Distance/800 -->
    <TEMPLATE MATCH="9.........." TIMEOUT="0"/> <!-- 10-Digit dialing -->
    <TEMPLATE MATCH="9......." TIMEOUT="0"/> <!-- External but local calls -->
    <TEMPLATE MATCH="*" Timeout="15"/> <!-- Anything else -->
    </DIALTEMPLATE>
