7960 Issues
Discussion in '3CX Phone System - General' started by tsunami_australia, Oct 28, 2011.
  1. tsunami_australia
    May 1, 2011
    30
    I have a 7960 driving me up the wall, I managed some time ago to fluke getting 4-6 extensions off a single proxy registration and cannot remember how. Now since a change of internal numbering scheme has been required.
    So I've made 4 proxy registrations instead all to the same extension/user/auth number and for all calls in and internal calls out this seems to work fine (allowing me to switch between different calls from different sources like if I'm talking to party-A and party-B rings I can hold A and answer B then switch between as I like).
    Now my issue is I cannot make external outbound calls. When the partners SPA942 rubbish dials out it dials xxxxxxxx@line interface:5060 however the 7960 dials xxxxxxxx@192.168.1.x (server ip) and gets a "reorder" with a failed dial tone.
    I assume it's something simple I've overlooked but be buggered if I can work out what.
    Please help.
    10,365
    227
    What does the 3CX log show for the call attempt? Does 3CX even get the call? If it does is it being blocked by a missing or incorrect outbound rule?
  3. tsunami_australia
    May 1, 2011
    30
    3CX as I said is seeing the phone.
    My 942 has the following during a call...
    08:40:35.046 [CM503008]: Call(87): Call is terminated
    08:40:34.937 [CM503025]: Call(87): Calling VoIPline:^dialednumber^@(Ln.10005@^ITSP1^)@[Dev:sip:^myDID^@^ITSP1^:5060]
    08:40:34.625 [CM503004]: Call(87): Route 3: VoIPline:^dialednumber^@(Ln.10006@^ITSP3^)@[Dev:sip:^myDID^@^ITSP3^:5060]
    08:40:34.609 [CM503004]: Call(87): Route 2: VoIPline:^dialednumber^@(Ln.10004@^ITSP2^)@[Dev:sip:^myDID^@^ITSP2^:5060]
    08:40:34.609 [CM503004]: Call(87): Route 1: VoIPline:^dialednumber^@(Ln.10005@^ITSP1^)@[Dev:sip:^myDID^@^ITSP1^:5060]
    08:40:34.609 [CM503010]: Making route(s) to <sip:^dialednumber^@192.168.1.2>
    My 7960 has...
    08:38:29.125 [CM503020]: Normal call termination. Reason: Not found
    08:38:29.125 [CM503016]: Call(84): Attempt to reach <sip:^dialednumber^@192.168.1.2> failed. Reason: Not Found
    08:38:29.125 [CM503014]: Call(84): No known route to target: <sip:^dialednumber^@192.168.1.2>
    08:38:29.109 [CM503010]: Making route(s) to <sip:^dialednumber^@192.168.1.2>
    08:38:29.093 [CM505001]: Ext.21: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7960G/8.0] PBX contact: [sip:21@192.168.1.2:5060]
    08:38:29.093 [CM503001]: Call(84): Incoming call from Ext.21 to <sip:^dialednumber^@192.168.1.2>
  4. leejor
    10,365
    227
    This would indicate that there is no match, in your outbound rules, for the number, that 3CX is receiving from the set. Compare your rules against the number sent (in the logs).
  5. tsunami_australia
    May 1, 2011
    30
    You would think that yet it was exactly the same number dialed on both phones with a very different outcome. The number in question I could dial a few days ago on the 7960 and I've not ammended any OB rules.
    I appreciate the input so far though :).
  6. leejor
    10,365
    227
    Does the log reflect the same number that you are dialling on the set? Can you dial the same number (show up as the same number in the log) from a different set (3CX softphone?), and have the call complete properly? Do you have extension specific rules in place, in the outbound rules?
  7. tsunami_australia
    May 1, 2011
    30
    No extension specific OB rules other than the niece who has a set pre-dialcode. Yes the exact same number can be shown on the log failing on the 7960 and succeeding on the 942, will post in a minute.
    From the Cisco phone...
    SIP Phone> sh config
    ------ Current *FLASH* Configuration ------
    Platform : Cisco Systems, Inc. IP Phone CP-7960G
    Elapsed Time: 00:07:01
    dhcp_server : 192.168.1.2
    my_ip_addr : 192.168.1.222
    subnet_mask : 255.255.255.0
    defaultgw : 192.168.1.1
    dyn_dns_addr_1 : 0.0.0.0
    dyn_dns_addr_2 : 0.0.0.0
    dns_addr : 192.168.1.2
    primary_tftp_addr : 192.168.1.2
    dyn_tftp_addr : 0.0.0.0
    my_mac_addr : 001b:d40b:8ea9
    domain_name : oriley.lan
    my_name : SIP001BD40B8EA9
    Status Flags : 12300000
    image_version : "P0S3-08-9-00"
    FirmLoadID : "PC030301"
    DSPLoadID : ""
    network_media_type : Auto
    network_port2_type : Hub/Switch
    dscpForAudio : 184
    phone_label : "Glen_ORiley"
    tftp_cfg_dir : ""
    phone_password : **********
    phone_prompt : "SIP Phone"
    language : english
    sntp_mode : DirectedBroadcast
    sntp_server : ntp.on.net
    time_zone : EAST
    dst_offset : 1
    dst_start_month : April
    dst_start_day : 0
    dst_start_day_of_week : Sun
    dst_start_week_of_month : 1
    dst_start_time : 02
    dst_stop_month : Oct
    dst_stop_day : 0
    dst_stop_day_of_week : Sunday
    dst_stop_week_of_month : 8
    dst_stop_time : 2
    dst_auto_adjust : 1
    time_format_24hr : 1
    date_format : D/M/Y
    nat_enable : 0
    nat_address :
    voip_control_port : 5060
    start_media_port : 16384
    end_media_port : 32766
    sync : "1"
    xml_card_dir : ""
    xml_card_file : "CARD.XML"
    telnet_level : 1
    services_url : ""
    directory_url : ""
    logo_url : ""
    http_proxy_addr :
    http_proxy_port : 80
    garp_enable : 0
    enable_vad : 0
    dial_template : "dialplan"
    callerid_blocking : 0
    anonymous_call_block : 0
    autocomplete : 1
    messages_uri : "99"
    dnd_control : 0
    preferred_codec : g729a
    dtmf_outofband : avt
    dtmf_avt_payload : 96
    dtmf_db_level : 5
    dtmf_inband : 1
    call_manager1_addr : "UNPROVISIONED"
    call_manager2_addr : "UNPROVISIONED"
    call_manager3_addr : "UNPROVISIONED"
    call_manager1_sip_port : 5060
    call_manager2_sip_port : 5060
    call_manager3_sip_port : 5060
    call_manager5_addr : "UNPROVISIONED"
    call_manager5_sip_port : 5060
    call_manager4_addr : "UNPROVISIONED"
    call_manager4_sip_port : 0
    line1_name : "21"
    line2_name : "21"
    line3_name : "21"
    line4_name : "21"
    line5_name : "UNPROVISIONED"
    line6_name : "UNPROVISIONED"
    line1_authname : "21"
    line2_authname : "21"
    line3_authname : "21"
    line4_authname : "21"
    line5_authname : "UNPROVISIONED"
    line6_authname : "UNPROVISIONED"
    line1_password : **********
    line2_password : **********
    line3_password : **********
    line4_password : **********
    line5_password : **********
    line6_password : **********
    line1_shortname : "21"
    line2_shortname : "21"
    line3_shortname : "21"
    line4_shortname : "21"
    line5_shortname : "UNPROVISIONED"
    line6_shortname : "UNPROVISIONED"
    line1_displayname : "21"
    line2_displayname : "21"
    line3_displayname : "21"
    line4_displayname : "21"
    line5_displayname : "UNPROVISIONED"
    line6_displayname : "UNPROVISIONED"
    line1_contact : "UNPROVISIONED"
    line2_contact : "UNPROVISIONED"
    line3_contact : "UNPROVISIONED"
    line4_contact : "UNPROVISIONED"
    line5_contact : "UNPROVISIONED"
    line6_contact : "UNPROVISIONED"
    proxy1_address : "192.168.1.2"
    proxy2_address : "192.168.1.2"
    proxy3_address : "192.168.1.2"
    proxy4_address : "192.168.1.2"
    proxy5_address : "UNPROVISIONED"
    proxy6_address : "UNPROVISIONED"
    proxy1_port : 5060
    proxy2_port : 5060
    proxy3_port : 5060
    proxy4_port : 5060
    proxy5_port : 5060
    proxy6_port : 5060
    sip_retx : 10
    sip_invite_retx : 6
    timer_t1 : 500
    timer_t2 : 4000
    timer_invite_expires : 180
    timer_register_expires : 600
    proxy_register : 1
    proxy_backup : "UNPROVISIONED"
    proxy_emergency : "UNPROVISIONED"
    proxy_backup_port : 5060
    proxy_emergency_port : 5060
    outbound_proxy : UNPROVISIONED
    outbound_proxy_port : 5060
    nat_received_processing : 0
    mwi_status : 0
    call_waiting : 1
    user_info : none
    cnf_join_enable : 1
    remote_party_id : 0
    semi_attended_transfer : 1
    transfer_onhook_enabled : 0
    call_hold_ringback : 0
    stutter_msg_waiting : 1
    cfwd_url : ""
    call_stats : 0
    auto_answer : 0
    speed_line2 : ""
    speed_label2 : ""
    speed_line3 : ""
    speed_label3 : ""
    speed_line4 : ""
    speed_label4 : ""
    speed_line5 : ""
    speed_label5 : ""
    speed_line6 : ""
    speed_label6 : ""
    local_cfwd_enable : 1
    timer_register_delta : 5
    sip_max_forwards : 70
    rfc_2543_hold : 0
    version_stamp : ""
    timer_keepalive_expires : 120
    connection_monitor_duration : 120
    encrypt_key : **********
    SIP Phone>
    SIP Phone> sh network
    ------ Network *FLASH* Configuration ------
    Elapsed Time: 00:14:18
    SIP Phone>
    SIP Phone> sh dialplan
    Dialplan is....
    Dialplan version:
    01. Pattern: 000 Rewrite: Line: All
    Timeout: 0000 UserMode: Unspecified RouteMode: Default
    02. Pattern: 2. Rewrite: Line: All
    03. Pattern: 12.... Rewrite: Line: All
    04. Pattern: 13.... Rewrite: Line: All
    05. Pattern: 1300...... Rewrite: Line: All
    06. Pattern: 1800...... Rewrite: Line: All
    07. Pattern: 02........ Rewrite: Line: All
    08. Pattern: 03........ Rewrite: Line: All
    09. Pattern: 04........ Rewrite: Line: All
    10. Pattern: 07........ Rewrite: Line: All
    11. Pattern: 08........ Rewrite: Line: All
    12. Pattern: 4....... Rewrite: Line: All
    13. Pattern: 5....... Rewrite: Line: All
    14. Pattern: 6....... Rewrite: Line: All
    15. Pattern: 7....... Rewrite: Line: All
    16. Pattern: 8....... Rewrite: Line: All
    17. Pattern: 9....... Rewrite: Line: All
    18. Pattern: * Rewrite: Line: All
    Timeout: 0006 UserMode: Unspecified RouteMode: Default
    SIP Phone>
    SIP Phone> sh register
    LINE REGISTRATION TABLE
    Proxy Registration: ENABLED, state: REGISTERED
    line APR state timer expires proxy:port
    1 111 REGISTERED 594 64 192.168.1.2:5060
    2 111 REGISTERED 595 65 192.168.1.2:5060
    3 111 REGISTERED 595 65 192.168.1.2:5060
    4 111 REGISTERED 595 65 192.168.1.2:5060
    5 ... NONE 0 0 undefined:0
    6 ... NONE 0 0 undefined:0
    1-BU .1x IDLE 0 0 undefined:0
    Note: APR is Authenticated, Provisioned, Registered
    SIP Phone>
    3CX logs next post
  8. tsunami_australia
    May 1, 2011
    30
    **** Showing the 2 different extensions making OB calls ****
    09:53:21.468 [CM503008]: Call(92): Call is terminated
    09:53:21.093 [CM505003]: Provider:[MyNetFone] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [ENSR3.0.6] PBX contact: [sip:09427060@121.44.166.69:5060]
    09:53:21.093 [CM503002]: Call(92): Alerting sip:09427060@sip00.mynetfone.com.au:5060
    09:53:20.390 [CM503025]: Call(92): Calling VoIPline:0265500387@(Ln.10003@MyNetFone)@[Dev:sip:09427060@sip00.mynetfone.com.au:5060]
    09:53:20.046 [CM503004]: Call(92): Route 3: VoIPline:0265500387@(Ln.10004@Pennytel)@[Dev:sip:8889244300@sip.pennytel.com:5060]
    09:53:20.046 [CM503004]: Call(92): Route 2: VoIPline:0265500387@(Ln.10005@Internode (4001))@[Dev:sip:0255084001@sip.internode.on.net:5060]
    09:53:20.046 [CM503004]: Call(92): Route 1: VoIPline:0265500387@(Ln.10003@MyNetFone)@[Dev:sip:09427060@sip00.mynetfone.com.au:5060]
    09:53:20.031 [CM503010]: Making route(s) to <sip:65500387@192.168.1.2>
    09:53:20.031 [CM505001]: Ext.11: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:11@192.168.1.2:5060]
    09:53:20.031 [CM503001]: Call(92): Incoming call from Ext.11 to <sip:65500387@192.168.1.2>
    09:52:55.062 [CM503020]: Normal call termination. Reason: Not found
    09:52:55.062 [CM503016]: Call(91): Attempt to reach <sip:65500387@192.168.1.2> failed. Reason: Not Found
    09:52:55.062 [CM503014]: Call(91): No known route to target: <sip:65500387@192.168.1.2>
    09:52:55.046 [CM503010]: Making route(s) to <sip:65500387@192.168.1.2>
    09:52:55.031 [CM505001]: Ext.21: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7960G/8.0] PBX contact: [sip:21@192.168.1.2:5060]
    09:52:55.031 [CM503001]: Call(91): Incoming call from Ext.21 to <sip:65500387@192.168.1.2>
    **** showing the 942 making a successful call ****
    09:54:53.359 [CM503003]: Call(94): Call to sip:21@192.168.1.2 has failed; Cause: 487 Request Cancelled; from IP:192.168.1.222:50238
    09:54:53.203 [CM503003]: Call(94): Call to sip:11@192.168.1.2 has failed; Cause: 487 Request Terminated; from IP:192.168.1.109:5060
    09:54:53.109 [CM503008]: Call(94): Call is terminated
    09:54:49.593 Currently active calls - 1: [94]
    09:54:47.984 [CM503008]: Call(93): Call is terminated
    09:54:47.750 [CM505001]: Ext.21: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7960G/8.0] PBX contact: [sip:21@192.168.1.2:5060]
    09:54:47.750 [CM503002]: Call(94): Alerting sip:21@192.168.1.222:5060;transport=udp
    09:54:47.531 [CM505001]: Ext.11: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:11@192.168.1.2:5060]
    09:54:47.531 [CM503002]: Call(94): Alerting sip:11@192.168.1.109:5060
    09:54:47.453 [CM503025]: Call(94): Calling RingAll20:21Ext.2111Ext.1112Ext.1213Ext.1314Ext.14@[Dev:sip:11@192.168.1.109:5060]
    09:54:47.437 [CM503025]: Call(94): Calling RingAll20:21Ext.2111Ext.1112Ext.1213Ext.1314Ext.14@[Dev:sip:21@192.168.1.222:5060;transport=udp]
    09:54:47.406 [CM503004]: Call(94): Route 1: RingAll20:21Ext.2111Ext.1112Ext.1213Ext.1314Ext.14@[Dev:sip:21@192.168.1.222:5060;transport=udp,Dev:sip:11@192.168.1.109:5060]
    09:54:47.406 [CM503010]: Making route(s) to <sip:20@192.168.1.2:5060>
    09:54:47.390 [CM505002]: Gateway:[GATEWAY_1] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-3.3.6(GW)] PBX contact: [sip:10000@192.168.1.2:5060]
    09:54:47.390 [CM503001]: Call(94): Incoming call from 10000@(Ln.10000@GATEWAY_1) to <sip:20@192.168.1.2:5060>
    09:54:47.375 [CM503012]: Inbound office hours rule (unnamed) for 10000 forwards to DN:20
    09:54:44.953 [CM505003]: Provider:[MyNetFone] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [ENSR3.0.6] PBX contact: [sip:09427060@121.44.166.69:5060]
    09:54:44.953 [CM503002]: Call(93): Alerting sip:09427060@sip00.mynetfone.com.au:5060
    09:54:44.328 [CM503025]: Call(93): Calling VoIPline:0265500387@(Ln.10003@MyNetFone)@[Dev:sip:09427060@sip00.mynetfone.com.au:5060]
    09:54:44.015 [CM503004]: Call(93): Route 3: VoIPline:0265500387@(Ln.10004@Pennytel)@[Dev:sip:8889244300@sip.pennytel.com:5060]
    09:54:44.015 [CM503004]: Call(93): Route 2: VoIPline:0265500387@(Ln.10005@Internode (4001))@[Dev:sip:0255084001@sip.internode.on.net:5060]
    09:54:44.015 [CM503004]: Call(93): Route 1: VoIPline:0265500387@(Ln.10003@MyNetFone)@[Dev:sip:09427060@sip00.mynetfone.com.au:5060]
    09:54:44.000 [CM503010]: Making route(s) to <sip:65500387@192.168.1.2>
    09:54:44.000 [CM505001]: Ext.11: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] PBX contact: [sip:11@192.168.1.2:5060]
    09:54:44.000 [CM503001]: Call(93): Incoming call from Ext.11 to <sip:65500387@192.168.1.2>
  9. leejor
    10,365
    227
    I haven't used the 7960 so I can't comment on the provisioning or settings. If the call is reaching 3CX as it is then the "basics" are working properly. For one extension to send a number and have it fail (not find a route) and another send the same number and have it succeed, then I have to assume that it is something to do with the extension number, or group that it is assigned to,and the outbound rules. Just a guess, not having seen your outbound rules.
    What you might try, since ext 11 seems to work, is assign that extension number to one of the 7960's. Just change the extension number and password manually if necessary. If the call goes through then you will have confirmed that is is a problem based on the extension number placing the call and not the set. Or, you can assign extension 21 to the SPA942 (maybe just to one key), and see if the call succeeds.
    The only thing I'm a bit curious about, and probably unrelated...
    Usually the DHCP server on small networks is handled by the router/Gateway, in your case 192.168.1.1. So the PC running 3CX is set up to do this?
  10. tsunami_australia
    May 1, 2011
    30
    Yes I was thinking of switching the extension temporarily to test that theory.
    As for the IP's, .2 is the 2k3 server housing AD(PDC), DHCP, TFTP, DNS, 3CX, VENT, Printer Sharing etc etc and .1 is the smoothwall router.
    I went with the 2k3 server as the dhcp since the router we had (that smoothwall replaced) would not resolve local machine names (eg. \\mediabox) for some stupid reason and so was easier to let the server run it all).
    Appreciate the feedback :) and I think you now see why I'm stumped.... since the phone seems to be doing all it should.
  11. tsunami_australia
    May 1, 2011
    30
    Ok tested line1 as ext11 which is working and whoala.... so it is something in the extension settings I'm guessing somewhere, But I cannot find ANYTHING different except the obvious 11 vs 21.
  12. tsunami_australia
    May 1, 2011
    30
    Just found out, anything that has a 1x extension number is fine and working (even newly made extensions) but anything with 2x is failing. I was hoping to change the internal scheme to 2x or better yet 2xx to avoid the issue of dialplans confusing 12xxxx and 13xxxx with 1x internal.
    So now I have have found the answer to my issue, my next question is, is there a way to change the internal numbering scheme to 2xx (eg. 201 202 etc) in 3CX?
    Just creating the extensions does not seem to work (well allows rx of external and tx+rx of internal but no tx of external).
  13. tsunami_australia
    May 1, 2011
    30
    Ok now I feel like a complete idiot, just found my problem ... when the niece come to stay I set her to ext19 and locked all but her dial code to ext 10-18 only thus not allowing ext21 to dial.
    So now I've changed the ENL to 3 and are in the process of setting everything to the 2xx standard and initial tests shows full success. So all I had to do in the 1st place was not overlook the extensions allowed setting in the OB rules :( lol.
    So thank you for helping support a bloody fool.
  14. shenglu
    Nov 2, 2011
    You can set different (3CX soft phone?) Dial the same number (displayed in the same number of logs), and call correctly?
