7962 is working but is slamming 3CX with errors
Discussion in '3CX Phone System - General' started by ajohnson443, Apr 10, 2012.
  1. ajohnson443
    Mar 27, 2012
    30
    7962 is finally working but causes massive errors:
    I checked the authorization section and it matches the extension cfg in 3CX.
    Keep in mind the phone works, dial out, dial in, internal, etc..
    <authName>1002</authName>
    <authPassword>uhsxo3x</authPassword>
    Errors:
    21:44:46.375 [CM102001]: Authentication failed for SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=a0048328 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 180 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:44:46.375 [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=a0048328 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 180 from(wire)
    21:44:42.265 [CM503008]: Call(60): Call is terminated
    21:44:41.187 [CM102001]: Authentication failed for SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=7fe34133 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 178 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:44:41.187 [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=7fe34133 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 178 from(wire)
    21:44:37.031 [CM503007]: Call(60): Device joined: sip:9046474349@sip.broadvoice.com:5060
    21:44:37.015 [CM503007]: Call(60): Device joined: sip:1002@10.232.1.68:5060;transport=udp
    21:44:35.984 [CM102001]: Authentication failed for SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=3211412e cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 176 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:44:35.984 [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=3211412e cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 176 from(wire)
    21:44:30.765 [CM102001]: Authentication failed for SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=227d2656 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 174 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:44:30.765 [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=227d2656 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 174 from(wire)
    21:44:25.562 [CM102001]: Authentication failed for SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=bbaf753e cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 172 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:44:25.562 [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=bbaf753e cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 172 from(wire)
    21:44:20.359 [CM102001]: Authentication failed for SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=83ee3246 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 170 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:44:20.359 [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=83ee3246 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 170 from(wire)
    21:44:18.890 Currently active calls - 1: [60]
    21:44:15.171 [CM102001]: Authentication failed for SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=14b854ee cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 168 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:44:15.171 [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=14b854ee cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 168 from(wire)
    21:44:14.781 [CM505003]: Provider:[BroadVoice] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:9046474349@108.197.214.151:5060]
    21:44:14.781 [CM503002]: Call(60): Alerting sip:9046474349@sip.broadvoice.com:5060
    21:44:13.281 [CM503025]: Call(60): Calling VoIPline:4646289@(Ln.10000@BroadVoice)@[Dev:sip:9046474349@sip.broadvoice.com:5060]
    21:44:12.750 [CM503004]: Call(60): Route 1: VoIPline:4646289@(Ln.10000@BroadVoice)@[Dev:sip:9046474349@sip.broadvoice.com:5060]
    21:44:12.750 [CM503010]: Making route(s) to <sip:94646289@10.232.1.66>
    21:44:12.750 [CM505001]: Ext.1002: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7962G/9.1.1] PBX contact: [sip:1002@10.232.1.66:5060]
    21:44:12.671 [CM503001]: Call(60): Incoming call from Ext.1002 to <sip:94646289@10.232.1.66>
    21:44:09.968 [CM102001]: Authentication failed for SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=f96b1230 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 166 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:44:09.968 [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=f96b1230 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 166 from(wire)
    21:44:04.765 [CM102001]: Authentication failed for SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=d123c6b8 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 164 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:44:04.765 [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=d123c6b8 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 164 from(wire)
    21:43:59.531 [CM102001]: Authentication failed for SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=a26cc140 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 162 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    21:43:59.312 [CM302001]: Authorization system can not identify source of: SipReq: SUBSCRIBE 10.232.1.66 tid=c3dcee60 cseq=SUBSCRIBE contact=1002@10.232.1.68:5060 / 1024 from(wire)
    21:43:59.312 [CM302001]: Authorization system can not identify source of: SipReq: SUBSCRIBE 10.232.1.66 tid=7eec94e2 cseq=SUBSCRIBE contact=1002@10.232.1.68:5060 / 1023 from(wire)
    21:43:59.234 [CM302001]: Authorization system can not identify source of: SipReq: SUBSCRIBE 10.232.1.66 tid=35543298 cseq=SUBSCRIBE contact=1002@10.232.1.68:5060 / 1022 from(wire)
    21:43:59.234 [CM302001]: Authorization system can not identify source of: SipReq: SUBSCRIBE 10.232.1.66 tid=ea2e525a cseq=SUBSCRIBE contact=1002@10.232.1.68:5060 / 1021 from(wire)
    21:43:59.234 [CM302002]: Authentication failed due to unidentified source of: SipReq: PUBLISH d0c282d03b99@10.232.1.66 tid=a26cc140 cseq=PUBLISH contact=d0c282d03b99@10.232.1.68:5060 / 162 from(wire)
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Check your phones configuration if you can disable PUBLISH mechanism. If you can't do this, you will continue see those errors.
