8 calls Limitation
Discussion in '3CX Phone System - General' started by amygoda, Jun 28, 2008.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    how 3CX system count the calls ?
    Is it by device ?
    If a conferance call is it like other calls ?
    and for what the g29 licenese ?
    the pbx establish and connect a call between 2 devices and the devices talk toghether to decide which code will use
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    its by call. And yes, if you want to have a conference call with 16 participants you need a 16 call version. The G729 license is required if you want to communicate on G729.
  3. SIPfun
    Jun 23, 2008
    56
    If you've got more than 8 people on a call... Chances are you can buy a copy that supports more people ;)
    For, so far in testing stages - at home I have 4 possible outgoing lines over VOIP... and 4 kids.. So far so good on the free version ;)
  4. SIPfun
    Jun 23, 2008
    56
    10 years with a nationwide phone company... who has VOIP & SIP customers, I"m only now learning about SIP because of 3CX. I know a lot about video/HD & codecs... Can I just buy a G729 "codec" from anyone, or is this brand specific????
  5. Thona
    Aug 10, 2007
    54
    Zou can buz a G719 codec from manz vendors - it is a standard, iirc it was done for digital mobile phones.
    Integratig with zour software is another thing, though - so for the 3cx phone szstem zou need to buz them from 3cx, as there is no way I know to get zour own codecs to work within 3cx, so a license from someone else would be - useless.
  6. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    I'M ASKING ABOUT THIS BECAUSE I WANT TO EXPLAN TO CUSTOMERS AND KNOW THE PRODUCT VERY WELL
    EXTENSION TO EXTENSION = 1 OR 2 CALL AND IS IT USE G29 LICENSES OR NOT
    EXTERNAL VOIP TO EXTENSION = 1 OR 2 CALL AND IS IT USE G29 LICENSES OR NOT
    EXTERNAL PSTN GATEWAY TO EXTENSION = 1 OR 2 CALL AND IS IT USE G29 LICENSES OR NOT
    AND IF A DEFFERENT IN VICE VERSA TELL ME
    THANK YOU
  7. SIPfun
    Jun 23, 2008
    56
    Ahhh.. My take from the comparison chart was that the 8 calls, referred to the incoming/outgoing CALLS -- not internal calls. I have no way to test that though.
