8 to 9 upgrade questions
Discussion in '3CX Phone System - General' started by Coldfirex, Nov 15, 2010.
  1. Coldfirex
    Nov 15, 2010
    5
    Howdy all,
    We are currently running a build of version 8 and are wanting to upgrade to v9 SP4. From what I have read the recommended way to do this is to use the backup utility, uninstall 3Cx, install the new version, and then restore from backup. Is this still the recommended way?
    Also, we are using Call Recordings for all of our calls. Will we need to include this in the backup/restore process? I started a backup with them included and it was still running 6 hours later.
    Thanks!
    Alan
    11,116
    329
    From what i recall during my upgrade, you will be asked (or it will just be done for you) to uninstall the previous version anyway, so you might as well do it before hand for a clean install of the new version.
    If you want to keep all of your recordings, then you will probably need to do a full backup before hand. Those more familiar with recordings and their locations may have another method of just copying them to temporary directory on the harddrive and then moving them back to a 3CX directory after the new version has gone in. If that can be done it would probably speed things up a bit.
  3. Coldfirex
    Nov 15, 2010
    5
    Thanks leejor!
    Would anyone else no for sure if maybe we can copy the recordings somewhere temporarily, make a full backup without the recordings, perform the upgrade, and then put the recordings back?
  4. scottyork
    Jun 1, 2007
    64
    Yes you can.
    On a standard install they sit in C:\Documents and Settings\All Users\Application Data\3CX\Data\Recording
  5. Coldfirex
    Nov 15, 2010
    5
    Thanks! This worked great.
