8SC Pro Google Compute sizing
Discussion in '3CX Phone System - General' started by Nick Harvey, Feb 21, 2018.
  1. Nick Harvey
    Feb 21, 2018
    15
    I have set up the above in a micro instance, and the customer isn't using it yet, just me testing. I am getting over-utilisation alerts from Google. Does this sound right?
  2. StefanW
    Jun 2, 2009
    1,199
    79
    I would not worry directly to much about this. The VM will be packed on RAM and this causes the warning. More keep an eye on the CPU usage as the micro is very limited in this (0.3 of a core with burst allotment). If you stay below 10ext you will be for sure fine in the micro, to play save you can upgrade at any time to small.
  3. tss956
    Feb 13, 2018
    7
    I'm running the 1 year trial with 16 simultaneous calls.
    I had the Management Console process killed because of insufficient RAM and upgraded to the next step, "small", instead. Been running perfectly since.
    YiannisH_3CX likes this.
