9999 ext has been hacked. V6
Discussion in '3CX Phone System - General' started by nahidul, Oct 14, 2011.
  1. nahidul
    Jul 9, 2007
    28
    Greetings.
    Someone hacked into my 9999 ext and making oversease phone calls. How do I stop it please? How do I change the password for 9999? How do I disable 9999 ext?
    Please help.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    763
    39
    Re: 9999 ext has been hacked
    If you are using 3CXPhoneSystem v10 goto Settings >> General >> Global Options and remove the tick behind “Enable Outgoing calls in Voicemail Menu”
  3. nahidul
    Jul 9, 2007
    28
    Hello.
    I forgot to mention that I am using the older v6. Please help.
  4. leejor
    10,567
    246
    You may also want to reconsider how much information you post (about yourself) on-line. It increases your risk of being a target of unscrupulous people that have a lot of time on their hands.
    You may also want to upgrade to version 10 as it has a number of security features.
  5. nahidul
    Jul 9, 2007
    28
    Hello.
    Now I see 8888 is being used to make phone calls. Any way I can stop this for v6? Thanks in advance for help.
  6. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Put a router in front of the 3cx and block all external requests to your 3cx system. You may allow only trusted addresses or use VPN tunnels. Mikrotik is inexpensive and powerful choice.
    Consider also upgrade (purchase of new licenses in your case) to version 10, which is self-protected.
    Regards
