A 3CXphone that can not make internal calls to one extension
Discussion in 'Windows' started by cesarlandazuri, Aug 10, 2015.
  1. cesarlandazuri
    Apr 30, 2015
    Hello
    I installed a 3CXphone (Extension 100) in a Windows 7 PC and I can recieve calls, make calls to other extensions, but I can not make calls to the operator Extension 101 working with a Yealink T21, the telephone do not rings and after the call is connected to the voice mail. This do not happens with other extensions. I check the 3CX systems and this was the result:
    10-ago-2015 16:19:09.794 Leg L:27.2[Extn] is terminated: Cause: 408 Request Timeout/INVITE from local
    10-ago-2015 16:19:09.794 [CM503003]: Call(C:27): Call to <sip:101@192.168.1.150:5060> has failed; Cause: 408 Request Timeout/INVITE from local
    10-ago-2015 16:18:49.817 Leg L:28.2[VMail] is terminated: Cause: BYE from PBX
    10-ago-2015 16:18:49.817 [CM503008]: Call(C:28): Call is terminated
    10-ago-2015 16:18:49.816 Leg L:28.1[Extn] is terminated: Cause: BYE from 192.168.1.35:5062
    10-ago-2015 16:18:35.910 Currently active calls - 1: [28]
    10-ago-2015 16:18:28.605 [CM503007]: Call(C:28): VMail:999 has joined, contact <sip:999@127.0.0.1:40600>
    10-ago-2015 16:18:28.604 [CM503007]: Call(C:28): Extn:101 has joined, contact <sip:101@192.168.1.35:5062>
    10-ago-2015 16:18:28.603 L:28.2[VMail] has joined to L:28.1[Extn]
    10-ago-2015 16:18:28.495 [CM503025]: Call(C:28): Calling T:VMail:999@[Dev:sip:999@127.0.0.1:40600;rinstance=2906fc15782f878f] for L:28.1[Extn]
    10-ago-2015 16:18:28.404 [CM503027]: Call(C:28): From: Extn:101 ("101 Operadora" <sip:101@192.168.1.150:5060>) to T:VMail:999@[Dev:sip:999@127.0.0.1:40600;rinstance=2906fc15782f878f]
    10-ago-2015 16:18:28.404 [CM503004]: Call(C:28): Route 1: from L:28.1[Extn] to T:VMail:999@[Dev:sip:999@127.0.0.1:40600;rinstance=2906fc15782f878f]
    10-ago-2015 16:18:28.403 [CM503001]: Call(C:28): Incoming call from Extn:101 to <sip:999@192.168.1.150:5060>
    10-ago-2015 16:18:21.528 Leg L:27.3[VMail] is terminated: Cause: BYE from PBX
    10-ago-2015 16:18:21.528 [CM503008]: Call(C:27): Call is terminated
    10-ago-2015 16:18:21.526 Leg L:27.1[Extn] is terminated: Cause: BYE from 192.168.1.4:51706
    10-ago-2015 16:18:05.772 [CM503007]: Call(C:27): VMail:999 has joined, contact <sip:999@127.0.0.1:40600>
    10-ago-2015 16:18:05.771 [CM503007]: Call(C:27): Extn:100 has joined, contact <sip:100@192.168.1.4:51706>
    10-ago-2015 16:18:05.770 L:27.3[VMail] has joined to L:27.1[Extn]
    10-ago-2015 16:18:05.620 [CM503025]: Call(C:27): Calling T:VMail:999@[Dev:sip:999@127.0.0.1:40600;rinstance=2906fc15782f878f] for L:27.1[Extn]
    10-ago-2015 16:18:05.568 [CM503005]: Call(C:27): Forwarding: T:VMail:999@[Dev:sip:999@127.0.0.1:40600;rinstance=2906fc15782f878f]
    10-ago-2015 16:18:05.568 L:27.1[Extn] forwards call from Extn:101 to VMail:999 based on rule Fwd[Available/NoAnsw]
    10-ago-2015 16:18:05.568 L:27.1[Extn] failed to reach Extn:101, reason No Answer
    10-ago-2015 16:18:03.908 Currently active calls - 1: [27]
    10-ago-2015 16:17:31.907 Currently active calls - 1: [27]
    10-ago-2015 16:17:20.523 [CM503025]: Call(C:27): Calling T:Extn:101@[Dev:sip:101@192.168.1.35:5062] for L:27.1[Extn]
    10-ago-2015 16:17:20.474 [CM503027]: Call(C:27): From: Extn:100 ("Softphone Prueba 1" <sip:100@192.168.1.150:5060>) to T:Extn:101@[Dev:sip:101@192.168.1.35:5062]
    10-ago-2015 16:17:20.474 [CM503004]: Call(C:27): Route 1: from L:27.1[Extn] to T:Extn:101@[Dev:sip:101@192.168.1.35:5062]
    10-ago-2015 16:17:20.473 [CM503001]: Call(C:27): Incoming call from Extn:100 to <sip:101@192.168.1.150:5060>
    10,878
    307
    Re: A 3CXphone that can not make internal calls to one exten
    Do calls to the operator extension, from any other Yealink T21 work correctly? Have you tried changing the extension number of the originating set to something other than 100?
    You don't have 3CX set to use extension 100 (originally) as the operator extension, in some of the settings do you?
