A couple parameters for templates needed
Discussion in 'Ideas' started by craigreilly, Feb 23, 2018.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    We have been on Grandstream phones for several years - of course - custom templates. Now that Grandstream is once again supported, I found something I need
    1) BLF assignment of a Ring Group (in this case - Multicast Paging Group)
    why? The light turns red when its in use. Folks just like the visual confirmation for some reason.
    2) Multicast Listener setup
    Thanks for listening. Keep up the good work!
