A DLL required for this istall to complete could not be found.
Discussion in '3CX Phone System - General' started by integrax, Jul 9, 2016.
  1. integrax
    Dec 9, 2008
    19
    We are trying to install new Ver 15 RC2 in a new Win 7 Fresh machine, and after required components got installed, we are getting following error:
    there is a problem with the windows installer package. A DLL required for this install to complete could not be found.
    Our concern is that Log file named Clud install and we are installing: 3CXPhoneforWindows15.msi
    3CXPhoneSystemCloud_install.log
    This is the last part of log file, and attached you will fin the full content.
    AI_InstallPrerequisite: Installing Visual C++ Redistributable for Visual Studio 2015 x64 completed
    MSI (c) (2C:A4) [17:21:18:868]: Note: 1: 2205 2: 3: AI_TempFile
    MSI (c) (2C:A4) [17:21:18:868]: Note: 1: 2228 2: 3: AI_TempFile 4: SELECT `Property` FROM `AI_TempFile`
    MSI (c) (2C:A4) [17:21:18:868]: Note: 1: 2205 2: 3: AI_XmlLocator
    MSI (c) (2C:A4) [17:21:18:868]: Note: 1: 2228 2: 3: AI_XmlLocator 4: SELECT `Property` FROM `AI_XmlLocator`
    MSI (c) (2C:A4) [17:21:18:883]: Note: 1: 2205 2: 3: AI_ChainedPackage
    MSI (c) (2C:A4) [17:21:18:883]: Note: 1: 2228 2: 3: AI_ChainedPackage 4: SELECT `ChainedPackage` FROM `AI_ChainedPackage`
    MSI (c) (2C:A4) [17:21:39:232]: Doing action: FatalError
    Action 17:21:39: FatalError.
    Action start 17:21:39: FatalError.
    MSI (c) (2C:10) [17:21:39:232]: Note: 1: 2205 2: 3: AI_ControlEx
    MSI (c) (2C:10) [17:21:39:232]: Note: 1: 2228 2: 3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'FatalError'
    Action ended 17:21:42: FatalError. Return value 1.
    MSI (c) (2C:A4) [17:21:42:055]: Doing action: AI_CleanPrereq
    Action 17:21:42: AI_CleanPrereq.
    Action start 17:21:42: AI_CleanPrereq.
    MSI (c) (2C:68) [17:21:42:055]: Invoking remote custom action. DLL: C:\Users\Admin\AppData\Local\Temp\MSIF1E9.tmp, Entrypoint: CleanPrereq
    Action ended 17:21:42: AI_CleanPrereq. Return value 1.
    MSI (c) (2C:A4) [17:21:42:071]: Doing action: FatalError
    Action 17:21:42: FatalError.
    Action start 17:21:42: FatalError.
    MSI (c) (2C:A4) [17:21:42:071]: Doing action: AI_SHOW_LOG
    Action 17:21:42: AI_SHOW_LOG.
    Action start 17:21:42: AI_SHOW_LOG.
    MSI (c) (2C:A8) [17:21:42:071]: Invoking remote custom action. DLL: C:\Users\Admin\AppData\Local\Temp\MSIF1F9.tmp, Entrypoint: LaunchLogFile
    Action ended 17:21:42: AI_SHOW_LOG. Return value 1.
    MSI (c) (2C:A4) [17:21:42:196]: Doing action: FatalError
    Action ended 17:21:42: FatalError. Return value 2.
    MSI (c) (2C:A4) [17:21:42:196]: Note: 1: 2205 2: 3: Environment
    MSI (c) (2C:A4) [17:21:42:196]: Note: 1: 2228 2: 3: Environment 4: SELECT `Environment`,`Component_` FROM `Environment`
    MSI (c) (2C:A8) [17:21:42:211]: Destroying RemoteAPI object.
    MSI (c) (2C:64) [17:21:42:211]: Custom Action Manager thread ending.
    === Verbose logging stopped: 7/8/2016 17:21:42 ===
  2. andreaschr
    andreaschr Support Team
    Oct 26, 2015
    93
    6
    Hi integrax,
    Please check that you do not have any pending updates then try to run the installer with administrator rights.
    If you still have issues with installing go into c:\users\"username"\AppData\Local\ then right click on "temp" and choose "properties" -> "security" -> edit -> add, and add the username you are using, and give yourself all rights.
  3. integrax
    Dec 9, 2008
    19
    Andreaschr,
    Thank you for your reply, and please let me tell you that I did all you mentioned even before to post my comment and unfortunately keep geeting same error results.
    Any other idea about a workaround?
    Thank you
  4. andreaschr
    Oct 26, 2015
    93
    6
    Hi integrax
    Please send me a pm so we can have a look.
  5. integrax
    Dec 9, 2008
    19
    Sorry, can't attach files to pm msg.
    We created a new user in a fresh Win 7 PC, and after verify admin access to ApData Temp folder, we did execute 3cx install msi as an administrator.
    After pre-software requirements installed, we still getting same DLL error, and noticed 2 important issues:
    1.- The error occurs when setup is configuring some XML files (as you can see in attached jpg)
    2.- The log file is named as Cloud Install (3CXPhoneSystemCloud_install.log) and we are installing locally.
    At this time we do not have Teamviewer installed in mentioned PC
    Please let us know if attached info is enough to troubleshoot this issue, or we need go further with it
    Thank you
