a line with this authentication id already exists
Discussion in '3CX Phone System - General' started by grasgruen.it, Feb 24, 2014.
  1. grasgruen.it
    Feb 24, 2014
    when I try to add a new Voip provider, I get this error because the same user is used with another provider. The Sip-Server address is different, so this seems to be a bug in the 3CX Phone System 12 with latest updates.
    Any workarounds?
    Thank you
    / Manuel
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Not a bug, it has always been this way. I suggest you ask for a new user id.
