A new update is available...
Discussion in '3CX Phone System - General' started by skRi11a, Jan 19, 2017.
  1. skRi11a
    Jan 11, 2017
    11
    I've been receiving an email notifying me of an update for a couple of days. Every time I check the updates, there's nothing listed.
    I'm on v15 Debian and was getting regular update notices and performing the updates with no issue until a couple of days ago.
    The system log shows this but I don't know if it's related:
    2017/01/19 10:48:05.900|9535|0007|Erro|Call type is invalid or not specified
    2017/01/19 10:48:05.901|9535|0007|Erro|Call type is invalid or not specified
    2017/01/19 10:48:50.353|9535|0007|Erro|Targeting segment is not found for target c59faa4b0df2
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    Hello @skRi11a
    Are you running the Beta test version of the Debian? If so then some updates do not appear in the update section as they are changed right away and you need to perform a
    apt-get update
    apt-get upgrade
    from SSH
    On the release candidate 15.0.60903.0. there is no update.
  3. skRi11a
    Jan 11, 2017
    11
    That makes sense. Thanks.
    I'm updating now and there are a few.
  4. Sopock
    Sopock Member
    Jul 11, 2012
    444
    20
    Or we can wait for auto update on Sunday?
    Good to see that now password of mail server is masked during setup and there is no crash when name of network interface is not eth0 ...
    Also fixed:
    #4 Sopock, Jan 20, 2017
