A-number transfer
Discussion in '3CX Phone System - General' started by frydendal, Jan 8, 2009.
  1. frydendal
    Aug 30, 2008
    16
    Is´t posible to transfer A-number
    A make a call to B (3CX, IVR), B (3CX, IVR) transfer the call to C (Ext. 100, 101, 102 or 103...) but the phonenumber from A (A-number) is not transfered with the call is´t posible?....
    Frydendal :?:
  2. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    Yes, this typically depends on your phones. It works well with Aastra phones for example.
    Mike
  3. frydendal
    Aug 30, 2008
    16
    Hi, Mike
    I use 3CX Softphone (in house) and Nokia E-serie handset - E51, E65, E66 and N95 (away) - when I use my Nokia-phones on BluePosition it´s working well but not on 3CX.
    Frydendal
