a page puts call on hold
Discussion in '3CX Phone System - General' started by mikeradio, Jan 19, 2012.
  1. mikeradio
    Jul 20, 2011
    12
    Hello
    3cx V10 SP5
    Cisco Spa525G Phones 7.4.9.c
    I have the phones set to auto answer a page, what we do is park the call, then page the phone to let the person know a call is on hold for them. Having the phone set to auto answer page allows the page to be hands free two-way audio. If the user is on a call and a page comes in the phone automaticly place the call on hold and answers the page. The phone should give priority to the call not the page.
    Thank you
    Mike
  2. efounco
    efounco New Member
    Sep 28, 2011
    148
    There are a couple ways of resolving/working around this issue with the SPA50x phones.
    1. Uncheck the "I want to be able to receive more than 1 call at a time - use Phone Status" option for the extension inside of 3CX.
    2. In the phone's "admin/advanced/ext1" WEB interface, set "Auto Ans Page On Active Call:" to "no"
    3. Add "<Auto_Ans_Page_On_Active_Call_1_ group="Ext_1/Call_Feature_Settings">No</Auto_Ans_Page_On_Active_Call_1_>" to the Cisco 50x provisioning template and reprovision the phones.
    4. If you're OK with the phone's built-in multicast feature (one-way audio only), simply dial 800# (the extension setup by default) and announce the caller. This will send a multicast page to all of the phones without interrupting current calls. This feature only works with SPA50x phones; you can configure the extension inside the phone's WEB interface.
  3. mikeradio
    Jul 20, 2011
    12
    Thank you efounco for your reply
    I did option 3 adding the setting to my provisioning template and it work perfectly
    Thanks for the help
  4. matrix1
    Jul 22, 2009
    Tfounco's option 3 is great, any idea how to accomplish the same with Yealink's?
  5. rbc94
    Apr 24, 2012
    40
    We have the yealink t28's and i ran into this problem too. there is an option in the phone settings for "intercom barge". turn this to off and it fixes the problem.
  6. countrycomp
    Dec 2, 2008
    53
    We have Yealink T28's at our clients sites and found the same problem when we started using multicast paging. For Multicast you need to set Multicast Paging priority to disabled which we did in the provisioning template. It is possible to set up to ten paging addresses with different priorities and only allow barge in from the priority levels that you select. You also need to set the multicast Paging Group to use that IP address/port and add that to the Contact list in the desired spot.
  7. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Looking forward to MultiCast paging in the T3x... We are feeling crippled.
  8. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Are you looking for these settings?
  9. craigreilly
    Feb 1, 2012
    3,575
    305
    No - the Yealink T38 doesn't currently support Multicast. After extensive conversations with China - they will be adding it to a firmware due out later this month.
  10. EricPatterson
    Nov 6, 2012
    Craig,
    I am trying to find the multicast setting in the new v38.70.0.80 firmware for the Yealinik T38s.
    Can you confirm that the setting has not been added to the firmware yet?
    This is something I would like to get set up as soon as possible.
