A range of IP Addresses
Discussion in '3CX Phone System - General' started by colin2710, Oct 31, 2007.
  1. colin2710
    Oct 29, 2007
    28
    Hi there,
    I am fairly new to 3CX, but I have got it working well - can one help.
    I am trying to add a range of IP addresses in the "Edit VOIP Provider" > "Other options <<" my first attempt was add IP addresses as "100.100.100.0-100.100.100.255" - but I get an error "Invalid IP-Addresses range".
    Can anyone help me what format I should enter?.
    Many Thanks - Colin
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please try 100.100.100.1-254
  3. colin2710
    Oct 29, 2007
    28
    Hi Ricky,
    Your a STAR - Many thanks, that works.
    Had a look at your web site - very nice.
    Regards - Colin
    :D
