Aastra 4422 IP outgoing call problem
Discussion in '3CX Phone System - General' started by miro, Apr 24, 2012.
  1. miro
    Jan 17, 2012
    51
    we are having problem with Aastra models 4422 IP, Dialog 4425, incoming calls work, but when we call there is always "busy" error, we have captured traffic on 3CX and there is "Proxy authentication required" in SIP messages from 3CX server, phone extension is registered without a problem, this is output from capture:
    INVITE sip:501@10.160.250.130 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.130:5060;branch=z9hG4bK31703.6dc.4842
    To: <sip:501@10.160.250.130>
    From: <sip:538@10.160.250.130>;tag=95805c18-4842.6dc
    Call-ID: 2af6-1eda-502b4728@192.168.0.130
    CSeq: 18499 INVITE
    Max-Forwards: 70
    User-Agent: Ericsson DBC422_02 HWVer-R3A ApplicRev-R6H BootRev-R3K
    Contact: <sip:538@192.168.0.130:5060>;g.ericsson.voip-p2p="true"
    Content-Length: 268
    Content-Type: application/sdp
    Supported: timer, 100rel
    Session-Expires: 1800
    Call-Info: <wap://192.168.0.130:2948>;wap-callref=21468
    Accept-Contact: *;g.ericsson.voip-p2p="true"
    Allow: INVITE, ACK, BYE, UPDATE, INFO, CANCEL, NOTIFY
    Proxy-Authorization: Digest username="538",realm="3CXPhoneSystem",nonce="414d535c05a7259a03:725ab1f1778f03968fd078d731e85cdb",uri="sip:501@10.160.250.130",response="0ce82bf882267fec1442edbe1f8098a3",algorithm=MD5
    v=0
    o=- 3353153344 3353153344 IN IP4 192.168.0.130
    s=D4 SIP-phone
    c=IN IP4 192.168.0.130
    t=0 0
    m=audio 17000 RTP/AVP 8 0 18 18 4
    a=rtpmap:8 PCMA/8000
    a=rtpmap:0 PCMU/8000
    a=rtpmap:18 G729/8000
    a=fmtp:18 annexb=no
    a=rtpmap:4 G723/8000
    SIP/2.0 407 Proxy Authentication Required
    Proxy-Authenticate: Digest nonce="414d535c05a725a147:bd80a69a4e76f884a2780701b563d277",algorithm=MD5,realm="3CXPhoneSystem"
    To: <sip:501@10.160.250.130>;tag=0713dd68
    CSeq: 18499 INVITE
    User-Agent: 3CXPhoneSystem 10.0.22539.0
    Content-Length: 0
    ACK sip:501@10.160.250.130 SIP/2.0
    CSeq: 18499 ACK
    Max-Forwards: 70
    Content-Length: 0
    We have tried with configured proxy IP address on phone and without it and its always the same problem.
    Please help.
    Best regards.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Can you provide the scenario with a little more detail? Where does the Ericsson fit in? I do not see what I might normally interpret as an outside call. Looks like an extension to extension call but from an internal network ip range using the system on a different internal ip.
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    1. This phone is designed for MX-One PBX.
    2. Other Aastra phones (which are not designed for specific use) don't have this problem
  4. miro
    Jan 17, 2012
    51
    I know this is phone designed for MX-One (i know it is not fully SIP compatible).
    But we have a potential client who has an erricson PBX and want to transition to 3CX.
    The problem is he cant afford new phones and he wants to make use of current IP phones if possible.
    Yes,this is normal from extension to extension call ( i havent tried calling over SIP trunk).
    Basiclly we are tring to enable basic interoperability between AAstra IP phone and 3CX.
    Is there any way we can disable proxy autorization on 3CX for this phones (maybe manually through editing 3CX scripts... )
    Thank you in advance.
