Aastra 480i on 3CX?
Discussion in '3CX Phone System - General' started by regomotiv, Dec 22, 2011.
  1. regomotiv
    Sep 15, 2009
    52
    Even though the 480 is an "old" phone, it's being used as part of a Fonality system that I'd like to convert to 3CX
    Is anyone using Aastra 480i on 3CX?
    10,864
    303
    Did you see....https://sites.google.com/a/3cx.com/3cx-wiki/phone-configuration/vendor-supported/aastra-1
  3. regomotiv
    Sep 15, 2009
    52
    Yes, I did. (Thx for the link)
    Those were the instructions I used & the phone does work.
    Some of the extra function buttons do not work, that's the main reason for my post.
  4. leejor
    10,864
    303
    Some of the extra/special functions not working properly (things other than "basic" functions), are one of the drawbacks of using older sets, or those not specificity tested (approved) to work with 3CX. And by "work", I mean all of the functions people will usually require in day to day operations.
    If you list the functions you are having trouble with, perhaps someone more familiar with the set can offer suggestions or work-arounds.
    One of the problems is that some sets were designed to work with specific PBX's or services and may not adhere to open SIP standards. Unless there has been a new firmware release that changes the function of a specific key(s), you may be out of luck getting it to do what you want.
  5. regomotiv
    Sep 15, 2009
    52
    That's kinda what I was hoping for, that someone out there was using this phone & figured out how to "fix" the extra functions.
    The last fw release on this phone was from '08
  6. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    I have an Aastra 9133i working on 3CX - for some time now. I use the buttons no problem. I can have a look at mine if that will help?
    Kind regards
    Richard
