AASTRA 53i setup MWI and PARK
Discussion in '3CX Phone System - General' started by sirdraco, May 29, 2009.
  1. sirdraco
    May 29, 2009
    I have been trying to wrap up our 3CX installation, but there are a couple of features holding us up.
    One is the ability to set a Message Waiting Indicator (voicemail indicator) on the programmable buttons for an extension other than the phones extension. Is this possible with the AASTRA 53i and 3CX? We want extension 101 to be able to see that there is a message waiting for Extension 110.
    The other issue we are having is the call PARK feature. I have tried the *00 and *01, but it doesn't work. I also tried the PARK feature on the AASTRA programmable buttons, but it doesn't work either.
    Any help would be greatly appreciated.
    Thanks,
    Chris
  2. zensoftware
    zensoftware New Member
    Aug 23, 2007
    225
    Hi Chris,
    Sounds like you are on the Free Edition?
    If so then I'm afraid neither of these features are included. MWI and Call Parking/Pickup are only available in the commercial editions.
    Hope this helps.
    Emmet.
  3. sirdraco
    May 29, 2009
    No. We have a paid mini license installed, with upgrade insurance.
  4. zensoftware
    Aug 23, 2007
    225
    Hi Chris,
    Hmm, it may not be registered correctly.
    If you install the 3CX Assistant do you get presence information on the other users?
    Also, install the 3CX VoIP Phone and try the * codes again, if they work then the phone may not be setup correctly if they dont work then it sounds like you license isnt registered correctly (we've seen this happend before), in which case try going back to the Free Edition and re-registering your license.
    Regards,
    Emmet.
