Aastra 6755i no audio in or out
Discussion in '3CX Phone System - General' started by ellenboa, Apr 20, 2010.
  1. ellenboa
    Apr 16, 2010
    5
    I have configured my Aastra 6755i IP phone to use my 3CX server. It is registering, i can establish a phone call, but no audio works. Not inbound nor outbound.
    Thanks in advance for any help.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Both audio streams not working might lead me to think its a stun issue. Also these phones are not supported I recommend you use on of the supported phones. Also you might try using the tunnel and see how you go.
  3. comresource
    comresource Member
    May 22, 2009
    303
    Is this an external extension or on the local LAN? If local, make sure the firewall on the 3CX box is not blocking RTP packets.
