aastra and 3cx
Discussion in '3CX Phone System - General' started by weebnuts, Oct 6, 2007.
  1. weebnuts
    Sep 13, 2007
    37
    I have a couple aastra phones, and after reading further and testing, I come to find out that they do not support the GSM codec. They do support G.729.
    I need to buy a couple more phones as well, but am wondering if I should go with Polycom or others, or hope that 3cx decides to somehow get G.729 working.
    thoughts or suggestions?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Referred to the following post. G729 support is not planned. They can provide an information how to write a codec's plug-in for Media Server.
    http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/how-to-make-the-ippbx-support-g-729-codec-2471/
  3. weebnuts
    Sep 13, 2007
    37
    I know it is not planned, but was hoping someone would come up with the plugin.
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    They are looking into adding it in the paid version. No timeframe yet that I know of though.
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    306
    You are correct Rob, we are negotiating with the G729 consortium about including G729 into the paid version.
    Note that we recommend SNOM, Grandstream above the Aastra phones. So if you are buying phones, buy those instead.
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Actually, the voice quality of Polycom should be the best especial at using speaker function. Hopefully, 3CX box can fully support Polycom.
  7. weebnuts
    Sep 13, 2007
    37
    well maybe I'll try the SNOM phones. Anyone have experience with SNOM and Polycom phones?
  8. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    We already tested Polycom, Linksys, Snom, Planet, Grandstream, Aastra, Wish and Sysmaster. I prefer Polycom.
  9. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    I have used the Snom 320 in the past with another PBX and had no problems at all with the phones.
    I currently use a Cisco 7960 and have no problems with it except, that I can't get the MWI to work with 3CX (minor issue).
    I have never been a fan of Polycom phones when I had to deal with them at a customers in the past. Don't think I would ever buy one.
    Just my .02¢
  10. weebnuts
    Sep 13, 2007
    37
    I guess everyone has a different opinion. I had used Cisco 7960's before, and they are ok, but didn't impress me much. oh well....
