Abandoned calls does not reset in Myphone
Discussion in '3CX Phone System - General' started by Uffe, Jul 25, 2012.
  1. Uffe
    Jul 15, 2012
    11
    does this happen to other than me? I have my queue statistics reset according to a schedule. It works fine, with one little exception: Abandoned calls in Myphone does not reset. (see picture)
    All other stats in Myphone resets properly and in Wallboard all stats reset, even abandoned.
    Any ideas?
    Best regards Uffe
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Out of curiosity, what happens if you exit the app and then restart? Does the counter then reset?
  3. Uffe
    Jul 15, 2012
    11
    No it doesn't. I have found no way to get rid of them. Resetting queue manually doesn't reset this either.
    /Uffe
  4. lneblett
    Sep 7, 2010
    2,061
    56
    Seems like a bug if all other aspects reset on all other mechanisms. Hopefully the3cx folks will see and address, but if you have access to support, I would submit a ticket.
  5. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    This issue is known and it will be fixed with next SP for v11.
  6. filipvds
    Apr 15, 2013
    33
    is it possible this is still not solved?
    I have the same issue. My queue wil reset every day. But the number of abandoned calls for the members of the queue doesn't reset. It only increments.
    Filip
  7. lneblett
    Sep 7, 2010
    2,061
    56
    I am running V11 with CCE and in my case, the abandoned calls are resetting along with the rest of the data on schedule - daily.
