ability for an extension to be able to manage Blacklist Numbers
Discussion in 'Ideas' started by craigreilly, Aug 16, 2017.
ability for an extension to be able to manage Blacklist Numbers 5 5 12votes
5/5, 12 votes
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,415
    277
    Would like the receptionist to be able to add Blacklist numbers.
    Security seems to granular right now to allow this.
    Nikola Paskov and jj1 like this.
  2. mortenjorge
    Apr 1, 2015
    59
    12
    I totally agree :)!
  3. jj1
    jj1
    Feb 23, 2012
    24
    I also agree
  4. Nikola Paskov
    Dec 11, 2017
    5
    Highly needed in call/contact centers feature - I already faced that problem in a deployed system - definitely should be added as a feature!!!
  5. Basaran
    Apr 1, 2011
    13
    I agree this feature needs to be implemented. Previously when I was using Freepbx I would just use a dial code after the call ended to add the last previous caller to the black list. Please add this feature - Thanks:D
    craigreilly likes this.
  6. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    789
    134
    I like both ideas, either a web interface to manage the numbers, or a CFD to add the previous caller to the list. If you need it now, both options can be implemented using the 3CX Call Control API.
  7. Stephan Gerber
    Oct 27, 2017
    I also agree!
    We got more and more "pishing phone calls" There must be a easy way to add Blacklist numbers!
  8. agentsmithitaly
    Jan 3, 2018
    31
    If it is possible to link blacklist functionality to a community-based blacklist, it would be terrific!
    This one is tremendously effective on my smartphone, and would be nice to see this at PBX level.
    https://www.shouldianswer.com/
    If not direct integration, at least an API to query service and parse response.
