Solved ability to access shared parking from the android client
Discussion in 'Android' started by Shawn, Feb 15, 2018.
  1. Shawn
    Shawn New Member
    Feb 2, 2017
    115
    is it possible to access the shared parking orbit from android clients (i'm not talking about *0 and *1 dial codes)
    i have setup shared parking blf's on our fanvil x4's and operators park calls on these sp locations but as far as i know, the android client does not have access to these locations and the only way to park a call to be accessible by the clients is transferring to *0 and picking up with *1
    do we have any options to customize the android client? perhaps replace the line buttons (kinda useless in our environment) with shared parking buttons.
    thanks
    shawn
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    12
    - There is no way to rename or change the Lines on the Android client.
    - The only way to use Share Parking on Android client is to forward a call to a Share Parking by answering the call first and then B.Transfer to SP0.
    - You can suggest any idea to the ideas forum for up-voting and evaluation.
    Thank you
  3. accentlogic
    accentlogic New Member
    Nov 14, 2013
    174
    72
    Marios - how can the mobile transfer to "SP0"? I don't see an option do dial alpha characters on the mobile app.
  4. Marios Neophytou
    Mar 1, 2016
    258
    12
    Hello @accentlogic,
    Follow the instructions below:
    1. Make a call to an Android Client
    2. While you are on the call press the Transfer button for Blind Transfer
    3. Click on the dial screen so the native Android keypad will be launch
    4. Type SP0 using the keypad and then click transfer
    accentlogic likes this.
  5. accentlogic
    Nov 14, 2013
    174
    72
    Excellent! I did find that the "SP" portion needs to be in CAPS, so SP1, SP2, etc. Also, touching the empty space above the 3CX number pad and lines list seems to be what "click on the dial screen" means, and that did bring up the Android keyboard.
  6. JMK
    JMK
    Jan 2, 2018
    26
    I originally put this in the ideas section but is more appropriate here:
    I'm sure others have seen this but if not I discovered that if you import your SPn numbers into the directory that you can avoid the invalid input errors and users can transfer in and out of Shared Parks without worrying about typing uppercase. I added "_" to the name so they are displayed at the top of contacts for quick access.
    To Park to SP1 from Android is: Trans/Contacts/_SP1/Call (no typing just clicks)
    To Pickup SP1 from Android is: Contacts/_SP1/Call (no typing just clicks)
    Example csv
    FirstName,LastName,Company,Mobile,Mobile2,Home,Home2,Business,Business2,Email,Other,BusinessFax,HomeFax,Pager
    _SP 1,,,SP1,,,,,,,,,,
    _SP 2,,,SP2,,,,,,,,,,
    _SP 3,,,SP3,,,,,,,,,,
    _SP 4,,,SP4,,,,,,,,,,
    jed, Marios Neophytou and accentlogic like this.
