Ability to add FAX Extensions to Extensions Groups
Discussion in 'Ideas' started by Flash99, Jan 9, 2018.
  1. Flash99
    Aug 3, 2017
    98
    8
    Its not possible to add FAX Extensions to Extensions Groups and as a result its not possible to create a specific outbound rule for FAX extensions
