Ability to add multiple conditions to outbound rules
Discussion in 'Ideas' started by Justin Scott, Mar 1, 2018.
Ability to add multiple conditions to outbound rules 5 5 1votes
5/5, 1 vote
  1. Justin Scott
    May 29, 2017
    21
    I have a client that is a medical practice. They have multiple trunks on the one 3cx system, and they all use the same speed dials, but those calls must go out on their own trunks.
    For instance, calls to **01 from extn 101 & 102 go out via one trunk.
    Calls to **01 (same end number) from 201 & 202 go out via their trunk
    and so on.
    Right now, I literally have to enter ALL speed dials (25 or so) for each trunk. UGH!
    My request is
    It would be great to set this filter in the outbound rule.
    So the rule would be
    Calls to **01 (or whatever)
    Strip 4
    Prepend (Full outgoing number)
    THEN
    From extension(s)/group etc.
    Trunk (Select Trunk)
    Add another
  2. Justin Scott
    May 29, 2017
    21
    Alternatively, the ability to COPY an outbound rule.
