Ability to change default double click action
Discussion in 'Ideas' started by Lance Lavery, Mar 14, 2018.
  1. Lance Lavery
    Mar 14, 2018
    12
    Hi all,
    Here is one feature I'm shocked hasn't been requested - Change default double click action.
    I don't know about everyone else, but I do not need to talk to my staff on the phone, we Instant Message.
    So the inability to set the default double click action or remap the sidecar contact in the desktop client to start instant messages is one huge no go for us.
    Yes I understand it's a phone system, but as with any business it needs to adapt to the client. We do not use the phones that often for interoffice communications we use instant messages. Chat is faster, has a record, and fills the interoffice communications need. But the lack of customization to address this is hampering. Yes I know, after a few months my staff will get used to it, but until then we will have phones ringing off the hook as everyone double click on the other staffs names and dials when all they wanted to do was chat.
    This has been the number one complaint from my testing staff so far.
    Lance
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,591
    309
    I call "my staff" frequently.... we have a real conversation and it happens quicker than typing back and forth and misunderstandings that result from quick 1 liners.
    This should be configurable by the end user perhaps - not a global system change.
    mortenjorge likes this.
  3. mortenjorge
    Apr 1, 2015
    59
    12
    Maybe enable this as an option, but not as global change - i suppose most of the clients use the double click to dial - atleast as i know :)
