Ability to change internal numbers of system extensions.
Discussion in 'Ideas' started by rz2, Jun 23, 2017.
  1. rz2
    rz2
    May 4, 2016
    Hi you all,
    it would be nice if the internal numbers/extension numbers for system extensions like "Fax FXS/ATA" (integrated faxserver) and "PIN protect IVR" could be changed or edited.
    I think this will be helpfull in customer enviroments with two digits numbering plans (eg. 11-99).
    Sorry for my bad english!
    Kind regards
    Andreas
    #1 rz2, Jun 23, 2017
    ntt2 likes this.
