Ability to change smtp port
Discussion in '3CX Phone System - General' started by nb, Jun 21, 2016.
  1. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Do you have any other issues apart from this? If the management console is crashing you might have DNX issue..
    in the meantime we are checking to see because we are adding default well known ports depending on whether you enable SSL or not..
    Nonetheless, we should respect your port configuration and if we don't, we will get this fixed.
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    12
    We have confirmed and if you have an smtp server running on a different port, you can add it to the "Mail Server" section example my.smtpserver.com:412 . The Handshake will be sent on that port.
