Ability to Configure Holidays for different Inbound Rules
Discussion in 'Ideas' started by Ben Ryder, Apr 13, 2017.
Ability to Configure Holidays for different Inbound Rules 5 5 13votes
5/5, 13 votes
  1. Ben Ryder
    Apr 13, 2017
    We deal with Opticians. A lot of them have different holidays depending on the branch location and how busy they are. For example we have a branch closing for Easter and they don't re-open for 4 days, yet they have another branch which is open after 2 days.
    At the moment, i have to go into the inbound rule, delete all opening hours and set the out of hours message as their Easter holiday prompt as we can't do a generic holiday prompt as it would be the same for all branches. I then have to set myself a reminder to go back into the inbound rule and change it all back again the day before they re-open.
    It would be much better if you could set different holiday prompts for different inbound rules (like you can with the opening hours)
    sersis01 and Matt Marshall like this.
  2. DL_
    DL_
    Mar 31, 2015
    55
    8
  3. rb1
    rb1
    Nov 17, 2016
    17
    That sounds like exactly what I want. The holiday Function is good, but you need to be able to specify which DIDs are effected. At the moment you can set one holiday and say if numbers are effected or not, but I want to set various holidays and say that dome DIDs are effected by one holiday and others by another.
  4. DL_
    DL_
    Mar 31, 2015
    55
    8
    @rb1
    So why can't you do that with the Voice Application Designer?
  5. GCollis
    Dec 11, 2014
    39
    6
    This should be standard and one should not have to purchase VAD to achieve setting holidays for individual inbound rules.
