Ability to deactivate a trunk
Discussion in 'Ideas' started by support@solutech.com, Jul 7, 2017.
Ability to deactivate a trunk 5 5 9votes
5/5, 9 votes
  1. support@solutech.com
    Jan 31, 2013
    We sometime have issues with certain trunk and need to be able to disable them. At the moment it's impossible even in the last version.
