Ability to disable ESC/Enter keys on 3CX Windows Client
Discussion in 'Ideas' started by c00ps, Mar 15, 2017.
Ability to disable ESC/Enter keys on 3CX Windows Client 5 5 5votes
5/5, 5 votes
  1. c00ps
    Sep 30, 2015
    Please can you add the ability to disbale Esc/Enter keys on the Windows Client.
    These are the same hoykeys our CRM uses, and if on the wrong screen, ESC cancels your current live call.
    Cheers
    martin-interforce likes this.
  2. Finn Grove-Knutsen
    Jul 31, 2017
    It would be great to have a solution on this, ESC key is very frustrating
  3. Sven Witlox
    Nov 16, 2017
    9
    same here, when pressing ESC results in terminating call. No matter what application is active.
  4. jed
    jed New Member
    Feb 1, 2010
    133
    37
    +1, we hear this as a complain as well from our customers.
