Ability to override extension rules from Queue
Discussion in 'Ideas' started by slsupport, Nov 16, 2015.
  1. slsupport
    Nov 16, 2015
    6
    Recently we had a scenario where a user said I don't want my cell# to ring if a call comes to me via a queue.
    But if someone calls my DID directly it should dial the mobile# and extension# simultaneously.
    We finally achieved the functionality with a weird workaround because currently the queue overrides all extension rules except the simultaneous mobile# calling.
    We should have a option in the queue (almost like a simple check box) to allow the admin to override extension rules completely from a queue. This allow for greater flexibility based on many scenarios.
