Ability to play goodbye Message in queues after maximum waiting time
Discussion in 'Ideas' started by actbig, Aug 18, 2016.
Ability to play goodbye Message in queues after maximum waiting time 5 5 1votes
5/5, 1 vote
  1. actbig
    Nov 20, 2015
    23
    7
    Add ability to play a goodbye Message in queues after the maximum waiting time and then to end the call.
    So far this is only possible when you connect to an IVR. The IVR will play the goodbye Message and end the call.
    The Problem is, that this is not a nice and clean solution, because while you connect from queue to IVR you hear the onhold music. Also sounds like "thankyou_goodbye.wav" or "pleasehold_calling.wav" which you do not want there.
  2. Eder Pardeiro
    Jul 8, 2017
    11
    I have the same problem....
    I change the file "thankyou_goodbye.wav" in English Prompt and my Personalized Prompt. Anyway it continues playing the original wav. If delete file, don`t play anything.
