Ability to record incoming and outgoing conversations
Discussion in '3CX Phone System - General' started by lonebobwhite, Feb 27, 2007.
  1. lonebobwhite
    Jan 26, 2007
    6
    Does 3cx have the ability to record incomming and outgoing conversations, or is there a 3-party application that is compatible with 3cx.
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    3Cx Phone System does not have the capability but many SIP phones do. For example X-lite allows you to record phone calls.
